3rd Party Software and Development
vMixTask [A new Scheduler for vmix with automated overlays control]
Joined: 10/25/2012(UTC) Posts: 181 Location: Barbados
Hi vfxblend, Any update on Status of vMixTask?
Maxi
Thanks: 1 times Was thanked: 32 time(s) in 10 post(s)
Hey guys, am uploading.. tutorials and the new version now... thanks for your patience
New version released to the the first page and download
A couple of things. 1.0.0.2
1. Would not load on a Windows 10 Home build (64bit). Tested on 2 separate machines. OK on Windows 10 Pro 2. On the working machine the maximize control does not work 3. The resize controls also do not work. (requires clicking on SHOW to see the playlist) 4. I cannot connect through to an version of vMix on another machine. 5. On the working machine when playing a clip Task Manager is reporting vMix @ Approx 6% CPU, vMixTask @ approx 15% 6. vMixTask does not add an icon to the task bar which means you have to ALT_TAB to get back to it if minimized or in the background 7. when minimized the maximize button floats over the left next to the logo 8. going back to a previously played clip does not trigger the clip to play in vMix unless you STOP, START, RETIME 9. Clearing the list leaves a file playing in preview. 10. on load, it picks up the last project. There is no option to open in the default state.
ask wrote:A couple of things. 1.0.0.2
1. Would not load on a Windows 10 Home build (64bit). Tested on 2 separate machines. OK on Windows 10 Pro 2. On the working machine the maximize control does not work 3. The resize controls also do not work. (requires clicking on SHOW to see the playlist) 4. I cannot connect through to an version of vMix on another machine. 5. On the working machine when playing a clip Task Manager is reporting vMix @ Approx 6% CPU, vMixTask @ approx 15% 6. vMixTask does not add an icon to the task bar which means you have to ALT_TAB to get back to it if minimized or in the background 7. when minimized the maximize button floats over the left next to the logo 8. going back to a previously played clip does not trigger the clip to play in vMix unless you STOP, START, RETIME 9. Clearing the list leaves a file playing in preview. 10. on load, it picks up the last project. There is no option to open in the default state. thank you very much for your comment 1. does your windows 10 home has .net 4.0 above? 2. Yes i made i so, its not resizeable on any platform 3. Yes that is the style of the app 4. why not, it should work. pls check your firewall settings 5. mine says vMix @ Approx 8% CPU, vMixTask @ approx 6.2%, what is your specs 6. sure will fix this out 7. will fix this out too 8. if its aired already, you have to click it twice 9. In a situation when you are on air, your channel shouldn't go black 10. will fix this
Joined: 1/30/2016(UTC) Posts: 5 Location: Douala Cameroon
Hello
i've encoutered the following error when adding a video file ( OS: win 10 pro )
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.IndexOutOfRangeException: Index was outside the bounds of the array. at VMixTask.mainWin.updateDuration(Int32 indx, String type) at VMixTask.mainWin.addClipButton_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
VMixTask Assembly Version: 1.0.0.2 Win32 Version: 1.0.0.2 CodeBase: file:///C:/Users/mvondondoumbe/Downloads/Compressed/vMixTask%201.0.0.2/vMixTask%201.0.0.2/VMixTask.exe
System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
AxInterop.AXVLC Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/mvondondoumbe/Downloads/Compressed/vMixTask%201.0.0.2/vMixTask%201.0.0.2/AxInterop.AXVLC.DLL
Interop.AXVLC Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/mvondondoumbe/Downloads/Compressed/vMixTask%201.0.0.2/vMixTask%201.0.0.2/Interop.AXVLC.DLL
System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
 1 user thanked brunolekid for this useful post.
Rank:: Advanced Member
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Yes. 4.6 All windows 10 installs include .net 4.0
which ports need to be open? Have got it working to some machines but not others....
Win10 Pro, Xeon e3-1271, 16 mb Ram. GTZ 780i
thanks
this links are only required for the first version vMixTask 1.0.0.0 then new one vMixTask 1.0.0.2 does only require .Net Framwork 4.0 above but will add it anyway. thanks
ask wrote:Originally Posted by: vfxblend thank you very much for your comment
thanks
1. does your windows 10 home has .net 4.0 above? 1. Yes. 4.6 All windows 10 installs include .net 4.0 --lol what was i thinking 4. why not, it should work. pls check your firewall settings 4. which ports need to be open? Have got it working to some machines but not others.... -- you need to copy the full address from vmix including the port -- on the machine with vmix, go to settings / web and copy the host address 5. mine says vMix @ Approx 8% CPU, vMixTask @ approx 6.2%, what is your specs 5. Win10 Pro, Xeon e3-1271, 16 mb Ram. GTZ 780i --am using lower specs, you've got a strong system. does this happen on all other machines?
version 1.0.0.3 NEW UPDATE INCLUDES: 1. Fixed addClip null exeption 2. Fixed Minimize to taskbar 3. Fixed Last Project option at startup 4. Donate button added to support this project
vfxblend wrote:ask wrote:vfxblend thank you very much for your comment
[/quote wrote:
Interesting, upgraded one of the home build to win10 pro and the program still will not launch. Anyone got any ideas? I really don't want to do a full reinstall of windows if at all possible.
_________________________________________________________________
Windows logs: _________________________________________________________________
Event Id: 1001 Windows Error Reporting
Fault bucket 129284873262, type 5 Event Name: CLR20r3 Response: Not available Cab Id: 0
Problem signature: P1: VMixTask.exe P2: 1.0.0.2 P3: 5832324d P4: System.Windows.Forms P5: 4.6.1586.0 P6: 575a140c P7: 5fd P8: 36 P9: PSZQOADHX1U5ZAHBHOHGHLDGIY4QIXHX P10:
Attached files: \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER690E.tmp.WERInternalMetadata.xml \\?\C:\Users\New\AppData\Local\Temp\WER6F78.tmp.appcompat.txt \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6F79.tmp.dmp \\?\C:\Users\New\AppData\Local\Temp\WER7074.tmp.WERDataCollectionFailure.txt
These files may be available here: C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_VMixTask.exe_6fe6d204628ba7457358b02d79cbb2edb1d9c5_38ae88c4_213d7071
Analysis symbol: Rechecking for solution: 0 Report ID: 6b2567ad-b696-476e-848c-fdad5c5fb270 Report Status: 4104 Hashed bucket: da97c26481988f5cc44b373a5cff3c09
______________________________________________________________________________
Event ID: 1000 Application error
Faulting application name: VMixTask.exe, version: 1.0.0.2, time stamp: 0x5832324d Faulting module name: KERNELBASE.dll, version: 10.0.14393.321, time stamp: 0x57f4c4f0 Exception code: 0xe0434352 Fault offset: 0x0000000000017788 Faulting process ID: 0x22b8 Faulting application start time: 0x01d243a37df43f76 Faulting application path: D:\Tools\vMixTask 1.0.0.3\vMixTask 1.0.0.3\VMixTask.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report ID: 6b2567ad-b696-476e-848c-fdad5c5fb270 Faulting package full name:
_______________________________________________________________________________ Event Id: 1026 .Net Runtime
Application: VMixTask.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.Runtime.InteropServices.COMException at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(System.Guid ByRef, System.Object, Int32, System.Guid ByRef) at System.Windows.Forms.AxHost.CreateWithLicense(System.String, System.Guid) at System.Windows.Forms.AxHost.CreateInstanceCore(System.Guid) at System.Windows.Forms.AxHost.CreateInstance() at System.Windows.Forms.AxHost.GetOcxCreate() at System.Windows.Forms.AxHost.TransitionUpTo(Int32) at System.Windows.Forms.AxHost.CreateHandle() at System.Windows.Forms.Control.CreateControl(Boolean) at System.Windows.Forms.Control.CreateControl(Boolean) at System.Windows.Forms.AxHost.EndInit() at VMixTask.mainWin.InitializeComponent() at VMixTask.mainWin..ctor() at VMixTask.Program.Main()
Another strange one. I can point at another machine and it works. Go back to my test machine and vMix task tells me the server is not running. Yet I can run the vMix WebController happily at the same address. I disabled all firewalls to ensure that wasn't the issue. No difference. Feature Request. Could we have a disconnect button? Also the ability to remember the ip addresses rather than going back to the default one each time? I would almost like it to build a drop down of previously used ones. Certainly would help with testing.
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
on Windows 10 enterprise built 14393.447 can't make it run, it instantly crashes.
 1 user thanked vfxblend for this useful post.
Thanks for your good work, I tried it, it works as well as it should. Now I use a program which is very good. http://forums.vmix.com/d...t.aspx?g=posts&t=999It works without any problems. I'm on my television. For several months I therefore urge you to develop your program according to this model. It would be a wonderful thing ever. I highly encourage you to do great things on. Thanks
the link to download is on the first page, i wonder why people cant find it, will move to my website soon
 2 users thanked vfxblend for this useful post.
any one having troble downloading?
You stopped the project? There is no more function like play pause stop dobrepossicion and communication by NDI
