External Output w/ Decklink Mini Monitor
Searched and couldn't find my answer so here goes.
Trying to get the Decklink Mini Monitor running in order to have a live studio monitor for our news broadcasts. Can't seem to get it to output correctly to show up on the LCD TV via HDMI. Gets signal, but no picture. Just wondering if anyone has any experience with the system and making it functional.
The TV input is getting signal (as the input is showing the right resolution I am sending), however there is no video on the screen. Output to External 2 is set as either Output or Multiview too.
Thank,
Joined: 8/22/2013(UTC) Posts: 92  Location: Rochester, NY Was thanked: 13 time(s) in 9 post(s)
We use one. I would play with the resolutions. There are some that work, and some that don't.
I think we send ours out at 720p60.
I do notice our monitor flickers every 10 seconds or so. Seems like an HDMI issue.
-Brian
tesn wrote:We use one. I would play with the resolutions. There are some that work, and some that don't.
-Brian Brian, thanks for the reply. Are you sending you external signals (the one that is streaming) and the one to the Decklink at the same frame rate?
Yes, same frame rate:    I'm using both the sdi and hdmi out of the mini monitor. HDMI goes to a computer monitor. SDI goes to a Hyperdeck Studio for recording. Only need to configure the hdmi out in vMix as the card sends a signal out of both outputs simultaneously. -Brian
 1 user thanked tesn for this useful post.
