swsslp
#1 Posted : Monday, December 24, 2012 1:20:53 PM(UTC)
swsslp
I got a 1920x1080 camera that has a frame rate of 25 that I want to use for my scoreboard camera, but I can't seem to get a picture from it connecting thru with my USB Capture card, which I know works as I used my 60 fps camera on it. Can I change the frame rate on the input to 25 for that camera?
Thanks,
Steve
#2 Posted : Monday, December 24, 2012 9:44:34 PM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
Hi Steve,
What is your USB Capture Card? The only USB device I know that supports 1920x1080 is the Blackmagic Design Intensity Shuttle.
swsslp
#3 Posted : Tuesday, December 25, 2012 6:27:23 PM(UTC)
swsslp
Using this:
http://www.ezcap.tv/usb-...re/ezcap116-capture-card
Camera:
Panasonic hdc-tm15
I know the USB capture works ok, as it works with my other two camera's (Sony HDV-100u and Cannon XF100)
ask
#4 Posted : Wednesday, December 26, 2012 7:47:34 AM(UTC)
ask
From the website you have linked to: Supports high quality video resolution: NTSC: 720 x 480 @ 30fps; PAL: 720 x 576 @ 25fps
Probably explains your issue.
swsslp
#5 Posted : Wednesday, December 26, 2012 5:38:50 PM(UTC)
swsslp
Is there any way for me to be able to use that camera? Perhaps firewire?
swsslp
#6 Posted : Wednesday, December 26, 2012 8:13:34 PM(UTC)
swsslp
Got it working on my laptop, but can't get it going on my Tricaster type computer for some reason.
swsslp
#7 Posted : Wednesday, December 26, 2012 10:19:11 PM(UTC)
swsslp
Figured it out. Now need to figure out how to crop or clone the scoreboard so that I can use both the game and penalty clocks for the hockey scoreboard.
