dmwanderley
#1 Posted : Saturday, January 14, 2017 10:11:46 AM(UTC)
dmwanderley
Friends, good morning.
I want to buy a Decklink mini recorder USB 3.0
You can tell if it works in Vmix?
I only got information from him with Thunderbolt connector
curtismacd31
#2 Posted : Saturday, January 14, 2017 10:52:09 AM(UTC)
curtismacd31
There is no USB3.0 mini recorder from Blackmagic. That is probably why you can't find info on it. They have a USB 3.0 intensity shuttle. I have heard in the rumors mill they are coming out with some USB3.1 (Type C) devices at NAB, but only time will tell.
#3 Posted : Saturday, January 14, 2017 10:55:23 AM(UTC)
Afaik I think this doesn't exist
BMD Mini Recorder models are PCI-e or Thunderbolt only
If you wish to stick to USB3.0 have a look at magewell devices (which work much better than BMD Intensity models) or search within the forum for other existing models
dmwanderley
#4 Posted : Wednesday, January 18, 2017 8:42:24 AM(UTC)
dmwanderley
Intensity Shuttle USB 3.0 Works with vmix?
In the supported hardware guide only thunderbolt appears.
If it works, I'll buy 2 of these for streaming sports.
Tks.
#5 Posted : Wednesday, January 18, 2017 9:31:39 AM(UTC)
It might work but many people have trouble with it
BTW, it is not a good idea to go for multiple USB3 devices (unless you have a PCIe multi channel USB3 extension card like this one for example https://www.startech.com...XUSB3S44V_Datasheet.pdf)
USB3 is limited to 5Gbps.
A 1080 fullHD video signal transported via HDMI 1.3/1.4 can have a bandwidth of 3.4Gbit/s so more than 1 will produce drops and problems....
If you use a desktop computer, you'd rather buy a PCI-e capture card with 2 or 4 inputs.
If you have a laptop with only USB3 ports, it's more complicated to have several inputs, unless you use Thunderbolt or USB3.1 type C
dmwanderley
#6 Posted : Wednesday, January 18, 2017 9:40:10 AM(UTC)
dmwanderley
A 1080 fullHD video signal is 3Gbps so more than 1 will produce drops and problems....
I have a DELL laptop that has 2 USB 3.0 ports, my idea is to connect 1 card in each port to connect 1 camera in each.
It would work this way?
Sorry for the errors in writing, I'm using google translator.
Tks.
#7 Posted : Wednesday, January 18, 2017 9:59:26 AM(UTC)
Not sure, USB3 is challenging sometimes, but maybe... if you stick to 720p or 480p.
#8 Posted : Wednesday, January 18, 2017 10:07:45 AM(UTC)
These Magewell USB3 devices work pretty well, I think better than Blackmagic Intensity models
https://www.amazon.com/M...deo-Dongle/dp/B00I16VQOY
I also found this (never tried but maybe somebody did)
https://www.amazon.com/S...re-Device/dp/B00PC5HUA6/
curtismacd31
#9 Posted : Wednesday, January 18, 2017 2:25:16 PM(UTC)
curtismacd31
Tks.
I have used the Intensity USB3.0, but like everyone else it has not been stable enough for me to rely on it. I would try the Magewell or the AJA U-Tap devices.
Curtis
stigaard
#10 Posted : Saturday, January 21, 2017 12:38:21 PM(UTC)
stigaard
Denmark
Curtis
I totally agree with you Curtis - I recommend to stick with Magewell XI100USB or AJA U-Tap.
