thecloudmediagroup
#1 Posted : Sunday, January 8, 2017 3:25:40 AM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
Hey everyone!
I just finished programming this graphic with all the fields for an XAML title. Everything is editable except the Foul lights which I am working on. You can change everything else including the team color. I finished this week getting some code integrated alongside "Data Sources" to auto update the title. The data comes from the Serial Output from our Daktronics 5000 board and is converted to USB with an adapter. This allows the title to completely run itself and mirror the arena scoreboard. I am hoping to make this available to everyone and wanted to give a preview!
thanks 6 users thanked thecloudmediagroup for this useful post.
corporatejames on 1/8/2017(UTC), Stavlin on 1/8/2017(UTC), Jedda on 1/14/2017(UTC), stigaard on 1/18/2017(UTC), tkachuk.alex on 1/19/2017(UTC), mackenlyj on 1/30/2017(UTC)
Bandit62
#2 Posted : Sunday, January 8, 2017 7:39:38 AM(UTC)
Rank: Guest
Groups: Guests
Nice....can we have it soon, where can we download it...
smudge1977
#3 Posted : Sunday, January 8, 2017 3:17:54 PM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
Have you written an external application to read data from the serial interface and post to the vMix API?
Could you expand on this please?
I have started experimenting with node-red and this would read from serial and then do the vMix API postings of the data fairly simply. With a Java Script function node you could easily set the foul lights too - i.e. if you set them as a picture and then use a green or red png
chipalinchik
#4 Posted : Friday, January 13, 2017 11:43:16 AM(UTC)
chipalinchik
It is very good that you have got to do this vesh. It may be able to tell you that the data did come to the schedule via .xml
Gary-WSN
#5 Posted : Wednesday, January 18, 2017 4:52:06 PM(UTC)
Gary-WSN
I've used dashes to indicate the number of timeouts. SImply create a text box in the XAML and title them HOMETimeouts and VISTimeouts. Then I create a shortcut for 5 timeous "- - - - - " as "set text". Then "- - - - " for 4 timeouts and so forth. I leave the field blank and have a shortcut for 0 timeouts. You can use whatever size font and color (I use yellow) for your indicators.
Gary-WSN attached the following image(s):
Screen Shot 2017-01-17 at 2.48.11 PM.png (151kb) downloaded 24 time(s).
goaliebob99
#6 Posted : Friday, October 5, 2018 3:38:18 AM(UTC)
goaliebob99
Is this available anywhere?
