contino
#1 Posted : Thursday, January 12, 2017 5:29:53 PM(UTC)
contino
I'm wondering if there's a way to turn a webcam off when another input is activated. The main reason I need this is so I can go into the webcam software and make adjustments while running vmix which it won't let me do until the webcam is off. Otherwise, I have to shut down vmix, adjust webcam, then restart vmix.
Is this possible?
Thanks!
ovinas
#2 Posted : Thursday, January 12, 2017 5:46:23 PM(UTC)
ovinas
Did you try the following:
Click the gear icon on your webcam input, go to "Advanced", click the "Properties" button. Now the configuration of your webcam should open to adjust your settings.
contino
#3 Posted : Thursday, January 12, 2017 6:09:32 PM(UTC)
contino
Thank you! That works .... I'd still like to see if I can turn off the webcam on command so I can then use it in my Zoom meeting room. I want to be able to switch back and forth.
But if it can't be done, I'll live with it.
AlanZ
#4 Posted : Thursday, January 12, 2017 11:08:38 PM(UTC)
AlanZ
You can simply close the camera's input in .vmix. Then .zoom can use it.
contino
#5 Posted : Friday, January 13, 2017 9:19:59 PM(UTC)
contino
Thanks ... after I close an input, I guess the only way of opening back up is to reload my saved inputs settings. I guess that'll have to do. :-)
