PFBM
#1 Posted : Tuesday, January 10, 2017 11:26:26 AM(UTC)
PFBM
Was thanked: 36 time(s) in 31 post(s)
HI !!
is there a chance to have better file support on Resolve 12.5 ?
Example : MXF VC3 ( DnxHD ) not working on resolve.
Cheers,
PFBM
#2 Posted : Tuesday, January 10, 2017 12:46:31 PM(UTC)
I can't have DNxHD packed in MXF to work in Resolve either but it works pretty well when you select MOV (indexed) as a container.
If you only choose MOV, you must use "Video Tool" provided with vMix to re-index the recorded file.
The only problem I found was the color space badly defined (as REC 601 instead of REC 709) which is an issue with FFMPEG
http://forums.vmix.com/d....aspx?g=posts&t=8617
Hope this helps
PFBM on 1/10/2017(UTC)
Peter B
#3 Posted : Wednesday, January 11, 2017 10:48:15 PM(UTC)
Peter B
It works in Premier but not in Resolve.
thanks 1 user thanked Peter B for this useful post.
PFBM on 1/12/2017(UTC)
PFBM
#4 Posted : Thursday, January 12, 2017 6:02:09 AM(UTC)
PFBM
Yes , i know....
thats why something is wrong....
and resolve is free.... premiere is not... :(
Cheers,
PFBM
