Steffoslovakien
#1 Posted : Tuesday, December 27, 2016 10:20:17 AM(UTC)
Steffoslovakien
Rank:: Member
Hi.
I installed the 60 days Trial version of Vmix 18 in my MacBook PRO (Windows 10 64-bit, Boot Camp).
All functions work perfectly, but there is no sound. I´ve tried to load all kind of video-files, audio files and computer microphone.
Looking at the meters in the audio mixer I can´t see any input activity at all.
It seems to be a major thing that I am missing.
Can anyone figure it out?
thickglass
#2 Posted : Tuesday, December 27, 2016 2:39:08 PM(UTC)
thickglass
I had the same problem, you need to install a/v codecs pack, such as xvid or quicktime for example
Steffoslovakien
#3 Posted : Tuesday, December 27, 2016 10:57:41 PM(UTC)
Steffoslovakien
Rank:: Member
thickglass:
I installed xvid and Quicktime but it didn´t help.
AnakoAlbert:
I have sound in Windows generally. I can play a movie clip, in VLC for example, with sound.
If I try to play the same clip in VMix = no sound (and no meter activities in sound mixer, both in and out channels)
I´m going crazy!
Steffoslovakien
#4 Posted : Thursday, January 5, 2017 6:56:47 PM(UTC)
Steffoslovakien
Rank:: Member
Does anyone more has any suggestions what can be wrong with my sound.
I feel like a jerk in this case, and my profession is Sound Engineer!
#5 Posted : Friday, January 6, 2017 4:28:43 AM(UTC)
Hi
did you check your audio outputs were right in "settings" ?
Make sure the default bus for inputs is set on MASTER and select the right MASTER OUTPUT for a start.
Do you use an external sound card or not?
If you open the audio mixer, do you see the VU meters moving when you plau something?
ovinas
#6 Posted : Friday, January 6, 2017 4:46:40 AM(UTC)
ovinas
He doesn't see the meters moving on the inputs so this has nothing to do with the settings for the outputs or internal/external soundcard.
I would download the newest version of vMix and reinstall.
It works perfect on my Macbook Pro with Bootcamp and Windows 10. No extras like codecs or so.
riverbill
#7 Posted : Sunday, August 30, 2020 2:18:25 AM(UTC)
riverbill
The sound through my monitor stopped working yesterday as well. Spent over an hour reinstalling GPU drivers and trying to block Windows from downloading an older version while I do it. Turns out if I just turned my monitor off then back on it would start working again. Found a fix here: https://techloris.com/windows-10-no-sound/
