ask
#1 Posted : Tuesday, December 18, 2012 11:09:34 PM(UTC)
ask
Does anyone have experience of streaming to a server on a LAN (i.e WMS) rather than to a CDN? Martin do you use such a setup for testing? Thanks in advance....
Egriswold
#2 Posted : Thursday, December 20, 2012 10:34:24 AM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
The easiest way is to setup using windows media encoder or VLC because both have built in settings for what's known as a pull and that's what you are doing.
The limit here is how many individual streams you are trying to accomplish because this puts a load on the streaming system which multiplies per system that is decoding the stream.
ask
#3 Posted : Thursday, December 20, 2012 6:15:19 PM(UTC)
ask
Thanks for that. I am not really looking to use VLC rather probably WMS as we want to be able to stream to a number of different clients during a live event, but all within the LAN.
DE_Mediaman
#4 Posted : Saturday, December 22, 2012 6:44:02 PM(UTC)
DE_Mediaman
Check out "Unreal Media Server". I use it to "pull" from the WMS encoder in vMix and then rebroadcast. The Unreal Media Server application runs on a dedicated 'fast' machine that outputs to a gigabit network. Only one stream is needed from the vMix system.
I have been using Unreal Media for a few years now. I believe it is still free for limited use. I think the free limit was 15 connections tops. Check them out at http://www.umediaserver.net
Hope this helps.
thanks 1 user thanked DE_Mediaman for this useful post.
ask on 12/23/2012(UTC)
ask
#5 Posted : Sunday, December 23, 2012 4:21:36 AM(UTC)
ask
This looks interesting. I am about to free up a machine and will trial it. Many thanks. Tech specs. Other than it runs on winxp I can't find any requirements. What is your "fast" box?
Similar Topics
streaming on a lan and recording at different resolutions. (General Discussion)
Belarus zentriloquy 4/20/2015 4:57:05 PM(UTC)
