Instant Replay
BUG - Incorrect default channel behaviour
Joined: 12/24/2016(UTC) Posts: 8 Location: Belfast, Northern Ireland
This may share DNA with this forum question: http://forums.vmix.com/d....aspx?g=posts&t=6823 My Camera 2 (live slomo) is mobile pre-game at my home ice hockey venue. The Camera 1 is fixed and good to go. Camera 2 joins the feed about 2 minutes into the game. When I set up my cameras 1x 1080i50, 2x 1080i50, etc. and enable instant replay the system interprets my *missing* camera 2 as being a 1080i59.94 (or 29..whatever) channel despite it being explicitly set up as i50. I assume this (missing) camera was part of a 1080i59 project, it would enable the channel, but as it is i need to remove the camera, start my replay, and stop/start whenever the camera comes back online (its mobile pre-game and fixed during-game). Does that make sense/any further info required? Thanks, David
Joined: 1/13/2010(UTC) Posts: 5,324  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Hi David,
What type of capture card are you using? vMix needs to have a valid signal at the time instant replay is created, so if there is no signal the capture card may display a standard signal (such as 59.94i) in its place causing the error.
Martin vMix
Hi Martin It's a Blackmagic Quad 2. So the "59.94i" might in a sense be a placeholder for "No signal"? If I have a bit of time later I'll set up a real camera + the replay system at 59.94 and see if i can get it to start without the second live signal in place. David
Instant Replay
