Maximus
#1 Posted : Saturday, December 24, 2016 4:28:45 PM(UTC)
Maximus
Hi Guys,
Can I do 8 ISO recordings on a System with 6700K CPU, 1080 Graphics Card, 32 Gigs Ram, 1 x 1TB Samsung 950 PRO M.2. Recordings will be mpeg .ts 720p at 25Mbs. Can this be done? Would it be better to use 2 Samsung 950 PRO and record 4 ISO on each? No Streaming or Program Recording will be done on this system. Has anyone done this many ISO?
Maxi
Mathijs
#2 Posted : Sunday, December 25, 2016 9:45:00 AM(UTC)
Mathijs
I don't think so, I can get 7 iso's on a 6-core Xeon E5-1660 running at 4Ghz.
Peter B
#3 Posted : Sunday, December 25, 2016 4:04:31 PM(UTC)
Peter B
Maybe if you used simpler codecs and transcode later if required. Win Media was always very efficient,
possibly MagicYUV but it eats space, Mjpeg, there's also the I frame only Prores available with FFmpeg.
VLC may have more options.
Maximus
#4 Posted : Monday, December 26, 2016 1:13:03 AM(UTC)
Maximus
What about an i7 6900K with X99 MB? Anyone tried this? How does that CPU compare to the E5 1660?
#5 Posted : Monday, December 26, 2016 3:35:32 AM(UTC)
Little known fact, if you install the free NewTek NDI Tools pack this will provide a new codec option for vMix AVI recording
called "NewTek SpeedHQ 4:2:2".
This is the same compression used in NDI and is very CPU efficient and it should be possible to record up to 8 on a 6 core processor.
thanks 3 users thanked admin for this useful post.
stigaard on 12/26/2016(UTC), Peter B on 12/26/2016(UTC), PFBM on 12/26/2016(UTC)
Maximus
#6 Posted : Monday, December 26, 2016 9:22:20 AM(UTC)
Maximus
Thank you much Martin and Merry Christmas. Looking forward to great things using vMix in 2017.
thanks 1 user thanked Maximus for this useful post.
Mathijs
#7 Posted : Monday, December 26, 2016 11:47:38 AM(UTC)
Mathijs
Nice, but will this also add support to load this into editing software, like Premiere?
Digitalson
#8 Posted : Monday, December 26, 2016 12:44:12 PM(UTC)
Digitalson
Groups: Guests
You have been a member since:: 1/17/2016(UTC)
Well iOS recording will need hard drive speed more than anything,so if u have a raid with 4 ssd's in a raid 0 configuration called stripping so all drives act as one and 4 times faster,I hit around 1700 gb per sec,also another option is a pcie ssd card ,and some of them can hit 2 gb a sec,,,,,I have never tried more than 4 iso at once ,,but in audio performance I can play more than 1500 audio tracks.....hmmmm wow!!!
Mathijs
#9 Posted : Monday, December 26, 2016 1:10:16 PM(UTC)
Mathijs
A single SATA3 SSD can do 500 MB/sec write these days, More than enough for 8 times 13MB/sec = 104MB/sec for the NDI recording, or 8x 35 MB/sec = 280MB/sec for MagicYUV. No special storage needs...
Peter B
#10 Posted : Monday, December 26, 2016 3:22:39 PM(UTC)
Peter B
Agree but I would probably use two SSDs, 4 on each, not so much for bandwidth but for redundancy.
You could also record a camera or two using the camera's internal card.
Check these out, 4 x M.2 striped, 9 GBs, not that you need it for this application -
https://www.servethehome...the-hp-z-turbo-quad-pro/
http://www8.hp.com/us/en...ns/z-turbo-drive-g3.html
Now if the PC clock could jam sync the timecode track on all the recordings and the SDI ancillary TC track ...
Mathijs
#11 Posted : Monday, December 26, 2016 5:07:41 PM(UTC)
Mathijs
To answer my own question: Yes, it also installs support for Premiere.
This has a big chance to become the new recording format I will use from now on.
What about fault tolerance?
