Hardware Compatibility
One Blackmagic Decklink Quad 2 or two Decklink Duo 2?
I don´t know what to choose. 1. One Blackmagic Decklink Quad 2 or 2. Two Blackmagic Decklink Duo 2 My needs are 8 inputs (sometimes 6 inputs an 2 outputs) My plan is to use put the card(s) in the Sonnettech Echo Express II http://www.sonnettech.co...duct/echoexpressse2.htmland use it with my Mackbook Pro (Bootcamp windows 10 64 bit) The question is if I get the same functionality in VMix regardless alternative 1 or 2? (If I choose two Duo 2, I don´t have to buy the DIN 1.0/2.3 to BNC cable bundle.) /Stefan
Tech Spec of Sonnet: Expansion Slot
One x16 mechanical (x4 electrical) PCIe 2.0(5) One x8 mechanical (x4 electrical) PCIe 2.0
Requirement of Decklink Quad 2: Computer Interface PCI Express 8 lane, compatible with 8 and 16 lane PCIe slots.
Requirement of Decklink Duo 2: Computer Interface PCI Express 4 lane, compatible with 4 and 8 lane PCIe slots.
So I think Quad will not work
Thanx ask. Due to the compability guide both cards will work. That´s great. But are there any obsticles on installing two Duo 2 cards? I´m thinking of speed issues etc.
And back to my original question about VMix: Do I get the same functionality in VMix regardless alternative 1 or 2?
2 duo's, we had issues with the quad 2.
 1 user thanked Ittaidv for this useful post.
