Joined: 5/3/2016(UTC) Posts: 28 Location: United Kingdom
Clicked on "upgrade available" and it downloaded file Version 18 and started installing but then came up with this message,
"C:\Program Files (x86)\vMix\vMix.exe
An error occurred while trying to rename a file in the destination directory: MoveFile failed: code 183. Cannot create a file when that file already exists.
Click Retry to try again, Ignore to skip this file (not recommended), or Abort to cancel installation"
I clicked Abort, but now I cannot run the original Version 17, states Windows cannot access the file.
How do I solve This?
David
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Reboot the computer before installing the update again, as there may be some program still running that is currently using one or more files in vMix.
admin wrote:Reboot the computer before installing the update again, as there may be some program still running that is currently using one or more files in vMix. Yes that worked many Thanks David
