Best Way to Execute a Series of Shortcuts
Hi all. I am really not trying to be lazy -- I should know how to this but just cant get it right.
I have Vmix HD.
Any suggestions on this issue?
I need to do the following in this order.
1) Select Next Item in a list (wish there was a "Last Item") 2) Play the video from the list 3) Make list the preview input 4) Fire a stinger It would be great to be able to go back to a specific input automatically after the video is completed but not absolutely essential.
I am basically using video delay as an instant replay.
When I try to line these up under the same shortcut using the advanced option, it skips over 1-2 events.
Is there a way to make these shortcuts happen - in sequence? I could do autohotkey but not sure if there is a better way.
Thanks as always!!
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ kjones9999
If I understand you correctly, I think you are on the right track as in my preliminary testing it seems to work fine for me, although I don't see the need to have a shortcut for playing the video, it should auto play after the stinger transition, also, the List needs to be properly configured to not "auto next". To return to live you can set up a "Trigger" to transition to a specific "Input" on completion.
Thanks Ice...
I am making some progress.
A few questions- 1) Can I trigger a stinger anytime a list video is played? It looks as though the trigger only applies to the individual video, not the entire list. 2) Just getting into triggers- It would be great if I could Stinger Transition-List Video to Stinger transition all automatically without any input from me. Is this possible?
