esmphoto
#1 Posted: : Friday, December 7, 2012 12:14:08 AM(UTC)
esmphoto
hello!
I've been experimenting with Vmix and several other software switchers, trying to find something new for my business to use.
Vmix is very attractive for several reasons, (price, modest resource consumption, ipad control) but is missing a few crucial components of our current workflow;
right now we use Teradek Cube encoders and Axis IP cameras in out productions, and from what I can tell these are not natively supported in Vmix.
Would it be simple too, or have you considered implementing RTSP capture support for devices like my Cube 220 encoder and Axis M1114 cameras? If so, do you have or are you willing to share any sort of timeline or roadmap for the implementation of these features?
Thanks so much, And keep up the good work!!
#2 Posted : Friday, December 7, 2012 2:38:31 AM(UTC)
Was thanked: 4719 time(s) in 1617 post(s)
We are currently working on support for the Teradek encoders which will also include basic RTSP support.
It's too early to say when this will be complete but there will be a forum post announcing the feature closer to its release.
esmphoto
#3 Posted : Friday, December 7, 2012 11:42:00 AM(UTC)
esmphoto
Awesome, I figured you guys would be working on it but I wanted to make sure.
Thanks!
ber142
#4 Posted : Sunday, December 9, 2012 4:59:31 AM(UTC)
ber142
For your AXIS camera you can also use the AXIS video driver capture (http://www.axis.com/techsup/software/capture_driver/index.htm) direct i.c.w. vMix.
Hanno.
