sagar
#1 Posted : Saturday, December 17, 2016 2:47:31 AM(UTC)
sagar
Hello
Is there any application which can capture take m3u8/f4m as source and capture it in HD format?
The requirement is to capture the source and use the growing file in FCP/Adobe Premier Pro for VOD creation.
Is it possible in Vmix or any other application?
If its possible in Vmix then what should be the record settings?
Sagar Shirke
