Remove a multiview overlay via a trigger?
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
I have a trigger that uses SetMultiViewOverlay to add a video file as an overlay to an multiview input. However, when I transition away from the input, I need to remove the multi-view's overlay.
The use case is that the input is a short video that shows a TV monitor dropping into the frame. When the animation is complete, I overlay another tutorial video into the TV monitor (via the multiview overlay 1)
When I transition away from the input, I need to reset the multiview so that overlay 1 is blank (otherwise the previously played tutorial video is on the screen during the animated TV dropdown)
I have done this successfully using a regular overlay channel, but would much prefer making this into a multiview if possible.
Any thoughts?
