Braindead
#1 Posted : Tuesday, December 13, 2016 12:01:33 PM(UTC)
Braindead
Yesterday I was capturing SD video from two different cameras through a Magewell dongle. Today I get an error message that says the dongle is not supported. I changed all the cables and the USB3.0 ports.
Same error message over and over. Any ideas?
zenvideo
#2 Posted : Tuesday, December 13, 2016 12:39:51 PM(UTC)
zenvideo
The first thing I'd do would be to check the dongle in Magewell's USB Capture Utility (a.k.a. Dongle Helper) to make sure it's working OK outside of vMix.
SportsNetUSA.net on 12/13/2016(UTC)
Braindead
#3 Posted : Tuesday, December 13, 2016 2:12:01 PM(UTC)
Braindead
I hate this but I think the dongle is toast. It gets hot! I did download the capture utility and it did not install automatically and there were no instructions. Several different folders but no instructions at all. Magewell does not offer customer service over the phone so I sent them a detailed explanation of the problem but I am not holding my breath.
Is there anything else like the Magewell available?
Thanks everyone.
ask
#4 Posted : Tuesday, December 13, 2016 5:17:01 PM(UTC)
ask
Was thanked: 199 time(s) in 181 post(s)
Thanks everyone.
Try contacting this company. They are the Amercian Agent for Magewell and handle RMAs
http://mobilevideodevices.com/
SportsNetUSA.net
#5 Posted : Tuesday, December 13, 2016 5:34:52 PM(UTC)
SportsNetUSA.net
The Magewell HDMI tool is on this page
http://www.magewell.com/usb-capture-hdmi/tool
It doesn't install. You just run the executable file USBCaptureUtility.exe.
It will tell you if you need to upgrade the firmware. Then click Signal and it will display setting and the video capture.
There is a quick start PDF in the folder that is unzipped, 20161201USBCaptureUtility.QSM.pdf
SportsNetUSA.net attached the following image(s):
zenvideo
#6 Posted : Tuesday, December 13, 2016 7:02:11 PM(UTC)
zenvideo
There's also a video on YouTube showing how the utility works. And yes, you have to run the .exe file in the unzipped folder that you download.
I'm sure you will get a response from support@magewell.net but bear in mind their location is Nanjing in China and they work normal (local) office hours.
Braindead
#7 Posted : Wednesday, December 14, 2016 9:28:25 AM(UTC)
Braindead
Thanks everyone.
Yeah, the folks at "mobilevideodevices" are really great.
Braindead
#8 Posted : Friday, December 16, 2016 8:27:15 AM(UTC)
Braindead
Thanks everyone.
They are a GREAT outfit.
Braindead
#9 Posted : Friday, December 16, 2016 8:45:54 AM(UTC)
Braindead
It was the Magewell dongle. Alan Z helped me diagnose the problem. I did run all the utilities but I was still unsure of the problem. Alan nailed it down.
Thanks to all for your support.
