h2video.nl
#1 Posted : Thursday, November 29, 2012 8:19:26 AM(UTC)
h2video.nl
For some recording sessions I want to use a VGA frame grabber. I prefer the build in desktop capture, but I am not always in a position to run the desktop capture program on the computer or laptop of my clients. This way I can just split the VGA output to the beamer and record it.
So I want to use a VGA2USB frame grabber. I use the Epiphan VGA2USB. When connecting I get a non-fatal error:
INPUT_CAPTURE.INPUT_CAPTURE
The specified property ID is not supported for the specified property set.
I think it has something to do with the frame rate or maybe an other type of mismatch (PAL ?). Nothing critical I can use the VGA grabber as a video capture input. Refresh rate is about 5 or 6 frames per second interlaced. That's good enough for powerpoint slides and simple animations.
If there is a preferred or alternative method for connecting this kind of device, Please let me know.
greetings
Stefan
#2 Posted : Thursday, November 29, 2012 8:52:49 PM(UTC)
Was thanked: 4739 time(s) in 1626 post(s)
Hi Stefan,
Please click Send Error Report when you receive this error so I can investigate further.
h2video.nl
#3 Posted : Friday, November 30, 2012 4:36:25 AM(UTC)
h2video.nl
I just did. Will do this next time when I get error's.
Greetings Stefan
