AdjustCountdown with MIDI controller
Joined: 9/26/2014(UTC) Posts: 109  Location: Canada Thanks: 39 times Was thanked: 5 time(s) in 5 post(s)
I may be doing something incorrectly but... I do not seem to be able to use the shortcut "AdjustCountdown with my Korg MIDI controller.
I have my scorebug working as I want it I have four (4) Penalty clocks that work great I am able to use the shortcut "AdjustCountdown" for the main clock using keystrokes
I can create a keyboard shortcut to adjust the timer of the penalty clocks
BUT
I cannot seem to accomplish this with assigning it to a event on the Korg MIDI controller
Is this by design or am I doing something wrong?
Whit
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
What Korg device do you have? I have a Korg Nano 2, Are you trying to use the sliders, or knobs?
 1 user thanked Cpilcher for this useful post.
Cpilcher wrote:What Korg device do you have? I have a Korg Nano 2, Are you trying to use the sliders, or knobs? Hi Yes it is a nanoKONTROL2 I am trying to use the R buttons along the bottom. I need 8 as I have 4 Penalty Clocks and need 1 each for adding and/or subtracting a second form the time. Thanks Whit
Ok. When I get home I will try to duplicate your shortcuts and see if there is any problem. Are you using the +1 commands?
Cpilcher wrote:Ok. When I get home I will try to duplicate your shortcuts and see if there is any problem. Are you using the +1 commands? I dont get the "value" field to open. I dont get a chance to enter the +1 Thanks Whit I bit the bullet and went ahead and assigned the AdjustCountdown to kys 1 thru 8 on the keypad on my laptop. Not that that is any big deal. I wont use them directly but the one keppress to add 1 to the main scorebug will also add 1 to the four penalty clocks. In a similar fashion another key will subratct 1 from all four clocks. Hoping this all soon to become a mute point. The R*D guy in Florida has finished a snippet of code (in Linux) to decode the serial data from the clock controller in the rink. I am hoping the Rasperry Pi will handle this, shoot across the rink to my laptop, have vMix gebnerate the scorebug graphic from the XAMl file. We shall see. In the meantime, the Korg MIDI controller will have to do.
Ok. When you program the Button on the Korg you need to check the box that says "value". It is near the find button at the top of the window. Once you check value the value box opens up where it is supposed to be.
I think this is different than the default for vMix 17.
Chuck
Cpilcher wrote:Ok. When you program the Button on the Korg you need to check the box that says "value". It is near the find button at the top of the window. Once you check value the value box opens up where it is supposed to be.
Chuck Worked exactly like you said it would, thank you Whit
