XML is much less used these days on the web than JSON for data transfer. I'd like to see JSON support added as a data source.
dnavarrojr wrote:XML is much less used these days on the web than JSON for data transfer. I'd like to see JSON support added as a data source. I would like this too. I have actually asked for this earlier, and the answer was, that JSON is easily converted to XML, and therefore, you can just extend your web service or program with a XML version of your API. Best regards Jens Stigaard
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
I would also love to have JSON support, all our stats a send through JSON.
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Hi all,
Do you have some JSON examples you can post along with how you want them represented as tables?
XML has the big advantage of XPath to find the exact data to convert to a table, whereas JSON can also have many levels of data but has no standardised way of converting to rows.
Thanks,
Martin vMix
I just sent you an e-mail with some JSON example data.
Thanks, A test JSON Data Source provider can be downloaded below: http://www.vmix.com/download/JSONDataSource.zipExtract the dll and place it in the vMix\datasources folder and it should show up as a new option. Let me know if it works as expected. Regards, Martin vMix
