NDI
Desktop Capture showing black screen with java app & Nvidia GTX 960m graphic card
Joined: 12/4/2016(UTC) Posts: 18   Location: Strasbourg Thanks: 3 times
Hi Everyone ! Nice to be part of the vMixer community :-)
I'm still using v17.0.0.112 v64 on my laptops - Asus UX501VW with nvidia Geforce GTX 960M graphic card / Intel Graphic 530 - Asus UX305U with Intel Graphic 520 I need to do a desktop windows capture from java application (java.exe & jawav.exe showing chess games). When running with Intel graphics, on both computer all is working fine (I can see the windows content), but when using nvidia Geforce GTX 960M, I have a black screen... I'm only speaking of desktop capture, not NDI-capture from another computer (this is working).
I configured both java.exe-javaw.exe & vMix using nvidia graphics : it didn't do the trick. I tried also vMix 18 with last desktop capture 18.0.0.18, but unfortunately the same result happened.
So now... it would be ok to use the "display" capture (working with java application) but I'm a bit "in zugzwang" (sorry, chess jargon : I mean "stucked") because win10, for some reasons, doesn't allow a fake monitor (but win8.1 does !)... and that I don't always bring with me "travel monitors" :-).
Any ideas on how to solve this issue ? Thank you !!
I have mentioned the same problem before (Asus gl552, GTX960M <> intel HD 530 )
Local desktop Capture only works when running vMix on the Intel but not on the GTX card, opening other items to capture on GTX Card does not help either ,seems a waste of the GTX
NDI
