Hello everyone there is a bug in Vmix 18 when we use the new List! When we drag n drop like 10 .png the list doesnt work properly! When i click on the png i want on the screen the list switch quickly to the last pictures and this crash vmix ... Thx for all :)
Element III wrote:Hello everyone there is a bug in Vmix 18 when we use the new List! When we drag n drop like 10 .png the list doesnt work properly! When i click on the png i want on the screen the list switch quickly to the last pictures and this crash vmix ... The List feature does not support images, but only Videos, audio and Playlist files, as it states when creating a new list. EDIT: Perhaps you should take a look at the Playlist feature, if you want similar behavior as the List feature. With the playlist you can add titles, images, and all other media, and choose the duration each item is shown. stigaard attached the following image(s):  Capture 2.JPG (19kb) downloaded 1 time(s). Capture 3.JPG (16kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
Thx thats what i saw but it would be great if this feature can support every format :)
Element III wrote:Thx thats what i saw but it would be great if this feature can support every format :) Take a look and try playlists and see if you can achieve what you want :-)
Hi Element III Asked something similar here with images and solved it using a slideshow (Photos) has auto-play, right click to see list and display selected image, continua with something else with "on completion trigger" etc
