Digitalson
#1 Posted : Saturday, December 3, 2016 9:16:00 PM(UTC)
Digitalson
Groups: Guests
When creating a list for say 2 commercials and I set the in points sometimes it works and not,also is not saved when saving a m3u file,also in either one there is no way to set a transition between the files.....any suggestions?
#2 Posted : Saturday, December 3, 2016 9:23:38 PM(UTC)
Very short videos (typically commercials), the video format may not allow accurate Mark In/Out depending on how it was encoded.
For these types of videos, it is recommended you edit them to size in a video editing program prior to use.
For the m3u export, this file format does not support Mark In/Out points so it is not able to be exported.
You can save a vMix preset instead to save this functionality, then recall just the List input into your existing production by opening the preset
and selecting just that input and clicking Append.
For transitions, the List does not support this feature at this time.
Hope this helps,
Digitalson
#3 Posted : Sunday, December 4, 2016 7:22:44 PM(UTC)
Digitalson
Groups: Guests
Also does the ndi premiere plugin work with ver 18 ? Also can I use the new ndi input boxes from newtek to add sources in vmix as well as outputs?
Digitalson
#4 Posted : Sunday, December 4, 2016 7:23:47 PM(UTC)
Digitalson
Groups: Guests
Also please make option to display timecode instead on seconds!!!
Cpilcher
#5 Posted : Sunday, December 4, 2016 7:30:02 PM(UTC)
Cpilcher
I can confirm Abobe Premiere NDI export works with v18.
