Animated, data driven, titles?
Joined: 10/14/2016(UTC) Posts: 65 Location: Sheffield
I can't be the only person wanting to achieve this so hopefully someone can point me in the right direction! I need to create an animated scoreboard that has 8 columns and 6 rows. The first two columns are name and country so can take the data directly from a spreadsheet. The next 4 columns are success or fail boxes and the last two are the numbers that represent the boxes (also comes straight from the spreadsheet. There are 2 issues I am facing. Firstly you don't seem to be able to address multiple rows of data in the data source for titles? Seems like a strange decision! Do you have to string everything together along one row if you want to display a live scoreboard? The second issue is making the success or fail boxes change colour based on a cell value. Is this even possible? I'm starting to think that it probably isn't! Any help on this would be much appreciated as I am really stumped at the moment. Thanks a lot. nomski attached the following image(s):  scoreboard.jpg (116kb) downloaded 52 time(s).You cannot view/download attachments. Try to login or register.
It is possible using value converters in codebehind Mind you I am far from an expert coder but thanks to the help of some fellow vMixers I was able to put this example together (prior to v18 datasources) by reading xml data files and base the ranking background colors on their value see in action in this postdoggy attached the following image(s):  value.jpg (225kb) downloaded 48 time(s).You cannot view/download attachments. Try to login or register.
I checked out the Youtube link and the screen shot and this is amazing! I literally have no idea where to even begin to do this. Is there a place with all the info for this kind of coding? I don't know how you are doing the animations or anything really. I'm very impressed and equally jealous!
Any knowledge on this that would help me would be awesome.
I think that advanced titles like this, is easier to handle with software like CasparCG.
Some I have done for basketball with XML Data, All graphics for XAMl are also pulled from the CMS
These are really good. Do you animate them in Blend or something? Or do you have to code it and then hope it looks how you wrote it? If that makes sense...
I'm from the video world not the code world. An after effects style layout that created the XAML for me would be the dream!
I am a "google" coder ;-) Changing color based on a cell value example using Blend, compiled into a .dll load as a vMix title any value > 0 in textblock will turn the square yellow Code:<UserControl
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:vMixTitleLibrary="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary"
mc:Ignorable="d"
x:Class="MainControl"
Height="1080" Width="1920"
<Grid Margin="223.5,235.5,0,0" HorizontalAlignment="Left" VerticalAlignment="Top" Height="681.833" Width="1397.415" RenderTransformOrigin="0,0" >
<TextBlock x:Name="Num" HorizontalAlignment="Left" Height="60.833" Margin="372.5,213,0,0" TextWrapping="Wrap" Text="TextBlock" VerticalAlignment="Top" Width="92" Foreground="#FFC6FF04" FontSize="48"/>
<Rectangle x:Name="Rect" Fill="#FFFFB900" Height="60.833" Margin="657.833,213,611.582,0" Stroke="Black" VerticalAlignment="Top"/>
</Grid>
</UserControl>
Code:Class MainControl
Private Sub MainControl_DataContextChanged(ByVal sender As Object, ByVal e as System.EventArgs) handles me.LayoutUpdated
If Val(Num.Text) = 0 Then
Rect.Fill = Brushes.White
Else
Rect.Fill = Brushes.Yellow
End If
End Sub
End Class
File Attachment(s):  ValueColor.zip (4kb) downloaded 91 time(s).You cannot view/download attachments. Try to login or register.
 3 users thanked doggy for this useful post.
Wow. Fortunately with the new datasources functionality I can do the changing of boxes etc. dynamically. However is there a tutorial anywhere for actually designing an animated title? It would be easy to use title designer to bring a .png add a load of text and image boxes etc. and then fill in all the data dynamically from my excel scoring system but I really want it to be animated like the .mov file attached which I did in after effects. Maybe I'm asking too much from XAML/my lack of knowledge? File Attachment(s):  Lower3rd1.mov (1,978kb) downloaded 84 time(s).You cannot view/download attachments. Try to login or register.
Per your mov example
look at the code for the animated titles included in vMix to get an idea (AnimatedInOutHD.xaml) play with the animations in Blend to create something like your example
no code behind needed, just xaml
Ok, I think I'm getting there! Thanks for the tip. Only thing that is a bit odd is that when I add a new timeline and do an animation it fails in vMix as it adds things in blend which don't seem to be supported in vMix. The error is:
"The tag "EasingDoubleKeyFrame" does not exist in XML namespace 'http://schemas.microsoft.com/winfx/2006/xaml/presnetation'. Line '5' Position '10'.
Is there something I need to update somewhere to make this work? Or do I need an older version of Blend?
Thanks again. I feel pretty close now! The only thing left is to get the animations to work as in and outs and it should be sorted.
The error needs to be solved by more knowledgable people , sorry
storyboard1 is the in animation , storyboard2 the out
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
For some reason in Blend when you create key frames they are created as "Double Easing" but you can only use "Keyspline" key frames. You need to select the key frames listed under each storyboard and make sure they are specified as "Keyspline"
Blend is very confusing to work with but once you get the hang of it you can make some awesome titles and graphics
Chuck
Thanks for the tip. It works with that added in. I've done my first successful title and I think I've "unlocked" it now. Let me know what you think. File Attachment(s):  Lower3rd1.xaml (19kb) downloaded 95 time(s).You cannot view/download attachments. Try to login or register.
Thumbs Up
though would get rid of :
<Run Text="FIRST "/><Run Text="SECOND"/> and <Run FontWeight="Bold" FontSize="22" FontFamily="Nexa Bold" Text="COUNTRY"/>
as it is messing up changing the content from within vMix
Just put <TextBlock x:Name="Name" Text="FIRST SECOND" and <TextBlock x:Name="Country" Text="COUNTRY" FontSize="22" ......
Glad you got it working. So many possibilities now. Keep sharing your ideas
I've now got a scoreboard and some other bits and pieces working. Something that would be awesome is being able to control the size of a rectangle from a data source. I.e. when an excel spreadsheet has "100" in it, make the rectangle 100 pixels wide.
Does anyone if that is possible?
Is possible Think about the example in post #8 but instead of color make it a rectangle size based on a input value and make that input itself hidden from display if you don't want to see the value Code:Rect.Width = Val(Num.Text)
Joined: 3/25/2019(UTC) Posts: 38  Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
Hi doggy,
I'm new in VmiX and I'm trying to change the color of a textbox based on a field in an excel file The color is writen in Hex
I found this post of you, but I don't know how to implement the code and the dll?
Can you please help me out?
Kind regards
Koen Deschepper
