ERROR: There is no Unicode byte order mark. Cannot switch to Unicode?
I have an XML data source I want to import information from to Vmix.
It starts with this line:
<?xml version="1.0" encoding="utf-16"?>
Other XML data sources I've imported so far do not even have a first line declaring a format and work.
Vmix throws this error:
Wondering if there is any workaround? I suspect Vmix wants the more common utf-8 format (ascii).
Any advice welcome, I can't post the data into a public forum, but can PM Vmix staff if helpful.
I don't think it's a bug, more a compatibility issue to work out.
I've parsed this XML URL with Javascript/AJAX and had no errors for a different purpose.
Thanks.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
The encoding setting specifies the actual encoding of the file itself. So if this heading is found in a file that is not actually in unicode format, then that error will appear.
This can happen if exporting utf-16 XML in .net but not specifying utf-16 encoding when saving to file.
Martin vMix
