4 Pages123>»
#1 Posted : Tuesday, November 29, 2016 9:26:30 PM(UTC)
vMix 18 has been released!
Visit the download page below to download and view all the changes:
http://www.vmix.com/software/download.aspx
Feedback
Please report any bugs or questions in this thread.
Thanks,
thanks 6 users thanked admin for this useful post.
vadim_d on 11/30/2016(UTC), BETech on 11/30/2016(UTC), vijay6672 on 11/30/2016(UTC), DYosua on 11/30/2016(UTC), smudge1977 on 12/4/2016(UTC), James Bond on 12/9/2016(UTC)
zenvideo
#2 Posted : Wednesday, November 30, 2016 6:50:00 AM(UTC)
zenvideo
A couple of smallish issues with the new direct support for Magewell cards.
1) When selecting a ProCapture Mini HDMI card, the only input option shown is SDI, which results in nothing being captured. Selecting the card in Legacy mode auto-detects the input OK.
2) When you select EmbeddedAllChannels for a Magewell card, but not all channels are present, the existing channels are duplicated on the remaining channels. Eg. if four channels are present, Ch 1,2,3,4 get duplicated onto 5,6,7,8. Not exactly a problem, just an observation.
zenvideo attached the following image(s):
boris9831 on 12/16/2016(UTC)
#3 Posted : Wednesday, November 30, 2016 3:12:33 PM(UTC)
To determine the ports available on a Magewell card, we use MWGetVideoInputSourceArray
Are you able to test InputSource example in the SDK to see if it is returning just SDI as well on that card?
If so, it means there might be a bug in the SDK.
Cpilcher
#4 Posted : Wednesday, November 30, 2016 4:51:49 PM(UTC)
Cpilcher
Data Sheets is a huge addition for me and your implementation has made it super easy to update my Preset to take advantage of them. It will remove a lot of user error opportunities, so thank you very much for the continuing improvement of an already awesome software.
I am testing using Google Sheets since I don't have Office installed on my Notebook (although I will mainly use Excel for my productions). I see in the documentation Excel offers a setting for "Use first row as Column Names", is this a possible feature for Google Sheets in the future?
I have also setup shortcuts for DataSourceNextRow / DataSourcePreviousRow, which are very helpful... Is there an ability to fade from one row of data to the next instead of a sharp "cut" as it is now?
Sorry if these are more of a feature request but it is just 2 quick questions that came to mind as I play around with these new features.
Keep up the great work. You continually make my tasks easier with each update.
Chuck
ichn1
#5 Posted : Wednesday, November 30, 2016 11:45:20 PM(UTC)
ichn1
Problem in Newtek mobile NDI app is not detected in this version of vmix
please fix asap
regards
#6 Posted : Thursday, December 1, 2016 12:03:56 AM(UTC)
ichn1,
We can confirm the NDI app is working on both Android and iOS with vMix 18 (just tested).
Couple of things you can check:
1. Double check wifi is connected and working
2. Make sure any updates in the app store for the app are installed
3. Make sure the record button in the app is red
ichn1
#7 Posted : Thursday, December 1, 2016 12:13:43 AM(UTC)
ichn1
Cant find Decklink SDI in the output for vmix , it is installed with latest driver
#8 Posted : Thursday, December 1, 2016 12:51:26 AM(UTC)
There have been no changes to Decklink support since 17, so check to make sure the device shows up in Blackmagic Media Express
as the list in vMix will match what is shown there.
sinc747
#9 Posted : Thursday, December 1, 2016 3:21:01 AM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Got this funky error message when setting up vMix Social & Facebook tonight. Any clues?
Also looks like the vMix Social Help is an older version as it does not show Instagram.
- Tom
sinc747 attached the following image(s):
vMix Social Error.JPG (52kb) downloaded 0 time(s).
#10 Posted : Thursday, December 1, 2016 3:42:50 AM(UTC)
Not sure why Facebook gives that error, but it usually means
it was unable to locate the page and post specified in the Facebook settings.
The key thing is that the post needs to be publicly accessible in order for vMix Social to be able to broadcast it.
ichn1
#11 Posted : Friday, December 2, 2016 4:24:11 PM(UTC)
ichn1
BIG BUG found
vmix 18 is losing the link with APC MINI during live production , this happened with us 4 times now during live .
trying to disconnect the apc mini usb and connect back dose not solve the problem ,you have to restart vmix to make the apc connected to vmix again , and this cant be done during live production
please fix or find a solution , we cant restart the vmix during live production.
stigaard
#12 Posted : Friday, December 2, 2016 5:07:30 PM(UTC)
stigaard
Denmark
ichn1 wrote:
BIG BUG found
I used a APC Mini for 3 hours straight this weekend on vMix 18.0.55 without any problems. Perhaps you have a USB port or cable problem. Try replace the cable and give it a try.
ichn1
#13 Posted : Saturday, December 3, 2016 8:50:11 AM(UTC)
ichn1
Actually , we have done this , the first thing we did is that we changed the cables and also changed the usb port , even we installed a new pci usb ports hub , to make sure that the problem might be with the built in ports , the same issue , vmix loses connections sometimes while we are on live production , the only solution is that we have close vmix and restart it again , but we cant do this while on live production , vmix needs to reconnect to all port automatically without any need of a restart .
hope this case is clear
coskel22
#14 Posted : Sunday, December 4, 2016 10:19:55 AM(UTC)
coskel22
Martin, have not had a chance to play with this yet, but I just want to give you a HUGE shoutout THANK YOU for the Data Sheets addition!!!!
smudge1977
#15 Posted : Sunday, December 4, 2016 2:28:45 PM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
Data sources
These are a brilliant idea - i was going to write something similar myself as I have may needs to interface vMix with other systems.
What can the format field {0} do - what langue can you use as a reference?
BUT THE BIG THING THAT WOULD BE EVEN MORE AMAZING
Read from serial port would be amazing as you can then easily interface with timing systems that send a serial data
I guess you need to know what the start and end markers are. This would be really good for things where speed is important like match timers and race times etc.
Amazing job and great product.
BEETECMEDIA
#16 Posted : Sunday, December 4, 2016 7:43:50 PM(UTC)
BEETECMEDIA
after I update to install it now vmix 18.0.0.57 after closing the program so what? What this latest vmix still many bugs? what's the solution?
#17 Posted : Sunday, December 4, 2016 7:49:00 PM(UTC)
Hi Beetecmedia,
Could you please describe any problems you are encountering in as much detail as possible?
There are no known bugs as of .57
Thanks,
zenvideo
#18 Posted : Tuesday, December 6, 2016 6:09:21 AM(UTC)
zenvideo
Did you get an email from Magewell on what the problem might be? (Now added to their Developer Notes)
ovonder
#19 Posted : Friday, December 9, 2016 7:28:04 AM(UTC)
ovonder
We lost all magewell inputs on all our systems (win10 anniversary) too, using the latest drivers.
The SDK does not have an installer. So what do we need to do to get them running again.
We use
Pro DVI, Dual DVI, AOI and Quad SDI cards, none of them are working in vmix18
1. Can you offer the link to vmix17 again on your website?
2. is there a way to disable the magewell native support, and just use DSHOW again in vmix18?
kind regards,
Oscar
zenvideo
#20 Posted : Friday, December 9, 2016 8:57:41 AM(UTC)
zenvideo
We use Pro Capture DVI, Dual DVI, AOI and Quad SDI cards, none of them are working in vmix18
There's two ways to get the Magewell cards working:
1) Set the rotary ID switches on the Magewell Pro Capture cards so that each has a different ID.
2) When adding the camera input, tick the "Show legacy devices" box and select the lower-down entries for the Magewell cards, in order to use the DirectShow driver. eg "Video (Pro Caapture)"
See attached images for illustrations of both these methods. Note that the cards with different IDs show as 00-x, 01-x 02-x (ID + Channel Number) after the product names.
Guest (5)
4 Pages123>»
