2 Pages<12
zenvideo
#21 Posted : Wednesday, November 16, 2016 6:14:09 AM(UTC)
zenvideo
Siroki wrote:
r@wisla wrote:
BTW,
Siroki wrote:
The audio was captured from NX30, ch1 commentary, ch2 hall..
This makes the commentary heared on one ear only. Quite annoying, specially when your viewer watches the stream with earphones.
Do you have cheaper and better solution? :)
When I talk to TV stations here they always do this way on interviews and stuff. On one channel is speaker and another is ambient. The audio is ok on live and no one didn't say it's bad or something like that. I learn this way from others, experienced people ;)
Best regards
Marko
You can easily fix this within vMix. Open the Audio Settings for the camera input and go to the Channel Mixer tab. By default the Ch1 & Ch2 inputs go to the L & R outputs respectively, but each input can be routed to either or both. By sending each input to both the L & R outputs you will create a mono mix, and at the same time have some control over the balance between the commentary and ambient/FX sound (which you may want to set lower, as shown on the right-hand example in the attached image file).
zenvideo attached the following image(s):
mburel1980 on 11/17/2016(UTC)
Siroki
#22 Posted : Wednesday, November 16, 2016 6:53:00 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
So on both channel in this way you turn L and R. On left channel (1) you turn on R and on right(2) you turn on L. So both channels are mixed?
zenvideo
#23 Posted : Thursday, November 17, 2016 6:25:09 AM(UTC)
zenvideo
Correct. Sending both input channels (1 & 2) to both output channels (L & R) will mix them together so both inputs appear on both channels of the output. Normally, when you have a stereo input on 1 & 2, you would want to preserve the stereo image (sending 1>L and 2>R), but in your case your inputs are two separate mono channels, so they need routing differently (as mono channels sent equally to both outputs, 1>L+R and 2>L+R).
Siroki
#24 Posted : Thursday, November 17, 2016 7:48:08 AM(UTC)
Siroki
thx
I will try this next time
best regards
Marko
Siroki
#25 Posted : Sunday, November 27, 2016 5:35:30 PM(UTC)
Siroki
We did another live stream of basketball tonight. You will see that I manage to fix camera looking similar each other. Colors first.
I didn't found channel mixer to put L and R like @zenvideo suggestion was. I am on vMix16 so I don't know is it able to do that?
Recorded match:
https://www.youtube.com/watch?v=K2x2HA98324
Best regard
Marko
#26 Posted : Monday, November 28, 2016 12:38:01 AM(UTC)
@ Siroki
Once again, great job Marko.
Thought that I should mention that I like your custom graphics and scoreboard. I was wondering how you are managing the clock, I'm guessing character recognition of some sort or is it an actual shot of the clock re-coloured?
#27 Posted : Monday, November 28, 2016 12:46:48 AM(UTC)
@ Siroki
Also, I can't remember which edition first provided support for L and R channels in the Audio Mixer, but I thought it was well before vMix 17...
Have you tried clicking on the cog wheel of the Input in the Audio Mixer window?
Siroki
#28 Posted : Monday, November 28, 2016 10:46:29 AM(UTC)
Siroki
IceStream wrote:
@ Siroki
Hi Ice,
thank you for reply. I shot clock with cheap dvi camera and insert it in vMix over USB like web camera. Than I make multi view and crop and position it on place where I want it. Than I go to camera input settings (cog wheel) and play little with lumia key, white strech, black strech, saturation and setup clock. :)) Simple as that
Best regards
Marko
Siroki
#29 Posted : Monday, November 28, 2016 10:47:30 AM(UTC)
Siroki
IceStream wrote:
@ Siroki
I tried a lot of buttons but didn't manage to find it. Tonight we are doing volleyball so I will check your suggestion
thx
Siroki
#30 Posted : Thursday, December 15, 2016 7:51:35 AM(UTC)
Siroki
Today we stream basketball to youtube for local TV station that will play recorded match one hour after the game is finished. It's some kind of test before we go live on TV
Basketball Cup semifinal game, 6:00 PM today, you can watch it here
http://www.hercegovinalive.com/...temid=100018&lang=hr
or youtube player:
https://www.youtube.com/watch?v=0hhxNs0KNIY
https://www.facebook.com/HercegovinaLive/
2 cameras, 720p, custom graphics, commentary
Best regards
marko
Siroki
#31 Posted : Friday, December 16, 2016 5:21:46 AM(UTC)
Siroki
We did a nice job. The game was on TV program and will be again today.
Recorded match:
Crew on half time:
Jedda
#32 Posted : Monday, December 19, 2016 6:40:43 PM(UTC)
Jedda
vMix is great for this, we show our local football teams matches (both home and away) live on a local tv channel aswell. Even with 4G we get great quality even for tv.
Siroki
#33 Posted : Wednesday, November 15, 2017 6:32:29 AM(UTC)
Siroki
New basketball season, new streaming demand:
All the same, one camera, 720p, 2mbits, custom graphics:
All home games thru season streaming live
Siroki
#34 Posted : Sunday, December 31, 2017 6:47:17 AM(UTC)
Siroki
Basketball Cup finals
https://www.youtube.com/watch?v=ATDDw20TaZo
Worked for TV station with 3 cameras (the 3rd on the floor was different brand so it doesn't look so good)
1080p, 3 cameras, commentary, atem tv studio, custom graphics made by me and input them over hdmi in atem with my pc Intensity pro output (external output vMix), crew communication
Siroki
#35 Posted : Friday, May 4, 2018 3:38:10 AM(UTC)
Siroki
Basketball finals of 2nd division:
1080p, 3 cameras, commentary, atem tv studio, custom graphics made by me and input them over hdmi in atem with my pc Intensity pro output (external output vMix), crew communication...
Guest (12)
2 Pages<12
