Feature Requests
borders around multiview inputs
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
Hi martin,
Would it be possible to add borders and corners around multiview inputs? Just as is possible with overlays.
Greetings Stefan
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
+1
and being able to fill the borders with a source.
+1
also the possibility to arrange the multiview in any way and any input at any place would be nice
Groups: Guests
Also user changeable source name overlays....and multi view with 16 inputs,no preview and program
 1 user thanked Digitalson for this useful post.
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
+ 1
I am not sure how possible or feasible this feature request is as each Input may have different requirements for Overlays, perhaps a toggle switch as per the settings of the master Overlay setting might be the simplest solution to implement (not ideal but workable).
@ xaver and Digitalson
I think you are mistaking the MultiView Output screen for the feature request on the "MultiView" Feature within each Input. Although those are valuable suggestions on their own, which I believe have been requested before.
Joined: 3/17/2013(UTC) Posts: 235  Location: Indiana Thanks: 95 times Was thanked: 30 time(s) in 28 post(s)
xaver wrote:+1
also the possibility to arrange the multiview in any way and any input at any place would be nice +1
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
Joined: 12/22/2016(UTC) Posts: 5 Location: Atlanta,Ga
+1 Multi view with boarders, no preview and program. Also individual color coding ability so the director will know what's pending, been seen, offline etc. Please don't under estimate the value of a control room style multi view for a broadcast workflow. Make it a separate component for $100
Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 18 times Was thanked: 17 time(s) in 14 post(s)
+1 h2video.nl wrote:Hi martin,
Greetings Stefan
+1, if so, please also add api command to enable/disable and change colour.
Feature Requests
