some issues with the RTMP Input:
we get the input from a HDMI Encoder over wowza streeming server works fine
except these problems:
a) no audio settings
b) the RTMB Buffer is fixed to 5000 msec you can set 1000 or 8000 msec if signal is lost (stream is lost) the buffer goes to 5000 msec
c) the audio signal didn't come back sometimes, if the stream was lost (close the input and add it again and the audio is there)
not sure if these problems are also in other versions
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
First, please don't post the same thing in two locations, it can be quite confusing.
For RTMP, vMix uses the Adobe Flash Player which is quite limited in its capabilities unfortunately. This can cause the issues you have experienced on some streams.
It is highly recommended you enable RTSP output from Wowza instead as the vMix support for this is far more robust.
Martin vMix
