windelf
#1 Posted : Wednesday, November 16, 2016 9:28:53 PM(UTC)
windelf
Hello!
I use pro-capture dual hdmi from magewell.
When I record a video using software provided by magewell, it works well without frame loss. the codec I used h.264.
But when I use vmix multicorder with H.264, it makes lots of frame loss(thounds of....)
Is there any difference of h.264 codec between magewell's byndle software and vmix?
If yes, is there any way to use codec used in magewell's software?
thanks!
Mathijs
#2 Posted : Thursday, November 17, 2016 5:15:00 AM(UTC)
Mathijs
Was thanked: 81 time(s) in 72 post(s)
If you only need 2 recordings, choose the FFMPEG option in recording and MPEG4 NVENC AAC.
You need a Nvidia card for this, and there are only 2 recordings possible with acceleration on a gaming videocard.
thanks 1 user thanked Mathijs for this useful post.
windelf on 11/17/2016(UTC)
windelf
#3 Posted : Thursday, November 17, 2016 11:44:20 AM(UTC)
windelf
But I need more than 2 recordings.. indeed max 8 channels of videos.
According to your post, vmix rely much on videocard, isn't it?
My graphic card is Geforce 1060. I wonder this graphic card is sufficent for multi channel recording.
And what is most improtant factors on multicorder recodings? CPU? graphic card? SSD?
