kjones9999
#1 Posted : Tuesday, November 8, 2016 12:21:32 AM(UTC)
kjones9999
Hi.
Need to send a UDP multicast stream using FFMPEG.
I realize at this point this cannot be done in Vmix, but is anyone doing this my using the external output directly into another instance of FFMPEG and could you share?
Siroki
#2 Posted : Tuesday, November 8, 2016 4:26:59 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
kjones9999 wrote:
Hi.
I think you can send UDP over VLC with vMix
There are some instructions on internet
pm
#3 Posted : Tuesday, November 8, 2016 5:18:44 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
You can do it like this:
On vMix PC:
- Enable External Output in vMix
- ffmpeg.exe -f dshow -i video="vMix Video":audio="vMix Audio" -b:v 1500k -f mpegts udp://remoteip:1234
For 'remoteip' put in a multicast IP address.
Patrick
Siroki
#4 Posted : Tuesday, November 8, 2016 6:25:06 AM(UTC)
Siroki
On vMix PC:
Patrick
So vMix can actually send udp?
Do you have some video tutorial for this?
pm
#5 Posted : Tuesday, November 8, 2016 7:18:13 AM(UTC)
pm
No, vMix cannot send a udp stream nativly.
But: vMix can send the output to external vMix Audio/Video direct show device. And from there ffmpeg can grab the video and send it by udp.
No, there isn't a video tutorial abut this.
Just try:
-Activate external output
-Download ffmpeg and open command prompt. Put in command with a vaild IP
-Open VLC to play the video
Mathijs
#6 Posted : Tuesday, November 8, 2016 8:21:07 PM(UTC)
Mathijs
Do you also know a good way to play the multicast stream to a browser without using plugins?
pm
#7 Posted : Wednesday, November 9, 2016 6:03:39 AM(UTC)
pm
No, I don't know a way without plugins. None of the current browsers is capable to receive multicast streams natively. Perhaps this will change in future...
