figueroaj
#1 Posted : Tuesday, November 8, 2016 7:12:34 PM(UTC)
figueroaj
I am looking for some assistance on my Vmix solution. I have a PTZOptics 1080P Camera running at 720p30fps running an RTSP stream I capture using Vmix BasicHD set to 720p30fps.
I am on the latest version of Vmix. I am recording to an Intel NUC5I7RYH with 16GB of DDR3 Ram and a Samsung 850 Evo M.2 500GB SSD.
I am getting a playback lag/frame loss error. On playback of video captured their are moments that the audio will be going but the video stream is at a standstill. The audio runs to the PTZOptics as well.
I have isolated the camera into it's own VLAN to see if that would help as well and have notice no change.
#2 Posted : Wednesday, November 9, 2016 12:57:45 AM(UTC)
To rule out a network issue, can you try the stream in the free VLC application:
http://www.videolan.org/
If it works fine there, try increasing the buffer size in vMix above 300. Try 1000 first
then work from there.
