bleachhun
#1 Posted : Wednesday, November 2, 2016 8:54:35 PM(UTC)
bleachhun
Desktop Capture Crash.
Computer 1:
Vmix Run
- Add Input -> NDI -> Select Display 1
(All preview Black)
Spec:
I3 Processor
Computer 2:
Desktop Capture Run
0FPS,0connections
0FPS,2Connections Working Stopped.
Spec:
Amd Phenom II X4 840
(MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V)
SSE4A = SSSE3 instruction set
Wikipedia.
NDI Spec: SSE3
Pls Help.
kane
#2 Posted : Wednesday, November 2, 2016 11:26:48 PM(UTC)
kane
I'm not sure that the AMD having SSE4a means that it also has SSSE3 (which is required by NDI).
Wikipedia lists only three AMD microarchitectures with SSSE3 instructions.
https://en.wikipedia.org/wiki/SSSE3
Kane Peterson
NewTek
bleachhun
#3 Posted : Thursday, November 3, 2016 8:37:27 AM(UTC)
bleachhun
vMix and NDI - what are the system requirements?
vMix 17 or higher
Intel or AMD processor supporting SSE3 or higher (This includes nearly all i5 and i7 processors released since around 2005)
kane
#4 Posted : Thursday, November 3, 2016 10:36:48 AM(UTC)
kane
I can't speak for vMix.
NDI requires a CPU with "SSSE3" instructions (yes, 3 letter 'S'), not SSE3. SSSE3 was first introduced by Intel in 2006 and I think AMD started adding to CPU's around 2011.
Kane Peterson
NewTek
bleachhun
#5 Posted : Thursday, November 3, 2016 3:40:20 PM(UTC)
bleachhun
http://www.vmix.com/ndi/
SSSE3? Not Write website SSSE3.
"vMix and NDI - what are the system requirements?
vMix 17 or higher
Window 7, 8 or 10 with 64bit recommended for best results
The number of simultaneous sources that can be sent and received will depend on the speed of the processor. A modest 3 Ghz PC can generally receive 4 full HD NDI sources (or more) at the same time."
kane
#6 Posted : Thursday, November 3, 2016 4:32:50 PM(UTC)
kane
I just looked through the SDK docs, looks like I may of been mistaken.
SSE3 is listed as the minimum. It does say that SSSE3 is taken advantage of, but I guess it isn't a requirement (but I always thought that it was). Sorry, my mistake.
