lbgaus
#1 Posted : Monday, June 6, 2016 4:03:39 AM(UTC)
lbgaus
I had a need this week to use an NDI source in vMix that was in a different LAN within our facility (the network engineers here have logically separated us into different VLANs). The design of NDI thus far doesn't allow for this, as it sends UDP broadcast packets to identify all NDI devices on the network as step 1 to using NDI. These packets, and all broadcast packets for that matter, do not traverse routers.
I ended up working up a little utility that would allow me to bypass this limitation and connect to an NDI source across different LANs, and wanted to post it here to get people's usage feedback. If you want to try it out, read the notes below to how it works.
1. There are 2 tabs in the program, tab#1 is to be used on the computer/network with the NDI source. Just click the button to enable the discovery service.
2. Tab#2 is to be used on the computer needing to connect to the NDI source in the other LAN. Type the IP address of the computer running the discovery service and click Connect. It should communicate with the remote side via TCP and continuously pull the NDI device hello packets across and rebroadcast them on the other LAN.
3. Once an NDI player has this hello packet, an NDI player connects to the IP address in the hello packet and doesn't care if it has to pass through a router to get there or not.
4. This is a one-way "extender" across different LANs, any NDI devices living/broadcasting on the other side won't show up to anyone on the original LAN.
5. This will NOT work over the internet, through NAT, etc... It likely wouldn't work because of speed/latency anyways, but random port numbers and rewriting the hello packets is just messy.
6. If you have a firewall between your different LANs, your network admin (or you :) will have to make a rule allowing both computers to talk unrestricted. Random ports are used by NDI, so it would need to be a rule allowing computer #2 to talk to any port on computer #1.
I hope NDI is updated at some point in the future to allow you to type in a remote IP address for usage cases like this, but for now this works for me. Let me know if it works for you or if it doesn't. Thanks!
File Attachment(s):
NDINetworkRelay.zip (142kb) downloaded 341 time(s).
thanks 6 users thanked lbgaus for this useful post.
fenki86 on 6/6/2016(UTC), vijay6672 on 7/8/2016(UTC), Amokka on 8/1/2016(UTC), shpoellet on 11/28/2016(UTC), Zetor1980 on 7/18/2017(UTC), majic_12 on 2/8/2019(UTC)
desmar
#2 Posted : Monday, June 6, 2016 11:16:09 AM(UTC)
desmar
Canada
You should request features directly to Newtek as I have done, the are very receptive to new ideas and are always looking to improve NDI ....
richardgatarski
#3 Posted : Monday, June 6, 2016 4:25:58 PM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
Thanks Ibgaus,
I will definetly check this one out the coming week! This issue is for sure relevant, and your solution seems like a great step forward.
Sound like something similar to Sienna's NDICloud (what I believe they earlier named "NDIRelay").
See also a related topic in NDI's forum.
diegog
#4 Posted : Tuesday, June 28, 2016 12:16:09 PM(UTC)
diegog
This is Great! Thanks to share... I want to try... but Avira stopped it because an tr/dropper.msil.gen alert... I understand that the antivirus might be wrong because the function of the soft... but I just wanna doble check with you...
lbgaus
#5 Posted : Tuesday, June 28, 2016 12:49:43 PM(UTC)
lbgaus
You should scan it with a different virus scanner. The tool opens tcp and udp ports on your computer so your Avira is probably hitting on that.
diegog
#6 Posted : Tuesday, June 28, 2016 2:48:23 PM(UTC)
diegog
yeah... thats what a thought...
thanks for sharing!!!
Frye
#7 Posted : Thursday, July 7, 2016 10:10:57 PM(UTC)
Frye
Does it work between live broadcast (maybe London) and master-control room (maybe America) ?
lbgaus
#8 Posted : Thursday, July 7, 2016 11:45:55 PM(UTC)
lbgaus
It isn't intended for WAN/Internet usage. It depends on your speed and latency. I especially dont recommend this for country-country connections but you can always try. If it does not work then it does not work.
Frye
#9 Posted : Friday, July 8, 2016 1:18:24 AM(UTC)
Frye
Does it only work on fixed IP ?
raster
#10 Posted : Tuesday, November 1, 2016 6:40:59 PM(UTC)
raster
Great tool. Thanks for sharing. It helped me demonstrate what we'll be able to do in the log run.
Tried also using it over a 4hr event and the NDINetworkRelay app running the Share Local Devices kept crashing about once per hour +/- 20min.
As long as I restarted the share within a few minutes the remote TriCaster receiving the feed would continue uninterrupted.
Another small glitch I ran into, on the TriCaster receiving the remote feeds, I could select right away any if the remote inputs but the remote outs would not show without waiting for a few minutes.
These could be issues specific to our network or crappy computer running the NDINetworkRelay, but I am willing to do further testing if it will lead to an update.
lbgaus
#11 Posted : Tuesday, November 1, 2016 7:03:07 PM(UTC)
lbgaus
Hi raster,
I noticed some similar issues to what you described so I need to do a little bit of digging to put out a bug fix.
Will let you know.
kane
#12 Posted : Wednesday, November 2, 2016 12:23:00 AM(UTC)
kane
NDI v2 has support to cross subnets. In fact, the latest downloadable NDI Tools download includes the 'Access Manager' application that allows you to set this up. You enter the IP address that you want NDI to access to and make sure to have ports 5960/TCP and an additional higher number port for each NDI source you want to connect to.
This does require that NDI v2 be running on both ends. Right now I think NDI Tools and NewTek IP Series system are the only tools out there with NDI v2 in the wild. The new SDK should be out soon so that other applications will be able to take advantage of this new feature.
Kane Peterson
NewTek
lbgaus
#13 Posted : Wednesday, November 2, 2016 12:27:36 AM(UTC)
lbgaus
Hi Kane,
This is awesome news! Look forward to the new SDK and having this functionality come baked in.
Thanks for the update.
Kane Peterson
NewTek
ask
#14 Posted : Tuesday, July 18, 2017 3:54:29 AM(UTC)
ask
Microsoft Defender is claiming that this tool is infected with a trojan and is quarantining it. Can you please check.
livepad
#15 Posted : Tuesday, July 18, 2017 4:16:39 AM(UTC)
livepad
Was thanked: 46 time(s) in 32 post(s)
If people are seeking a mechanism to transport NDI sources over the internet or over long distances, you may find NDI.Cloud of interest
mjgraves
#16 Posted : Tuesday, July 18, 2017 12:34:33 PM(UTC)
mjgraves
Since this is not already mentioned in this thread, you could use a small router, or computer with two NICs, as a gateway to connect your remote source to your production network via VPN.
This approach often requires adding a device. Even so, using a VPN makes the remote device effectively local, which can be very handy.
