7 Pages<1234>»
Cpilcher
#21 Posted : Wednesday, October 19, 2016 4:58:21 PM(UTC)
Cpilcher
You need to install 18 over version 17. make sure it is in the same folder as the original install. When you want to go back to 17 just reinstall over the top of 18 and everything should be back. Ive never done this but Martin mentioned this process on the LiveStream.
Chuck
thanks 1 user thanked Cpilcher for this useful post.
SHMD on 10/23/2016(UTC)
Slaver
#22 Posted : Wednesday, October 19, 2016 6:08:40 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
I have a quick question to the data sources.
Want to save statistics for a sportsgame in one textfile. So i need to seperate the data in columns in vmix. But how to write it in the textfile that vmix knows thats a new data columns has to be created? Maybe Tab, Comma oder semicolon is a good solution.
Thank you !
Maximus
#23 Posted : Wednesday, October 19, 2016 7:59:24 PM(UTC)
Maximus
I am trying out the activators on Behringer CMD series. I believe the LED options are Default (Orange), Blinking Blue, and Solid Blue. The activators only provide 'OFF' (Default Orange) and 'Blinking Blue' options. Am I missing something?
Maxi
madness
#24 Posted : Wednesday, October 19, 2016 8:43:56 PM(UTC)
madness
Using CSV format, you create a new column with each comma on the same line.
#25 Posted : Thursday, October 20, 2016 3:13:23 PM(UTC)
SHMD wrote:
Can I test a few features of VMix 18 on my production PC and then roll back to VMix 17?
I install it in other directory so have both then
Rinsky
#26 Posted : Thursday, October 20, 2016 3:58:21 PM(UTC)
Rinsky
Ash wrote:
Instant Replay Right Click to Add Clip to Play By ID List
Possible to have a right click on a replay event and the pop up menu has an add to "Replay Stack" to quickly add to the Play By ID list? Also a play stack button or in the pop button.
And Left click drag to move to another event, right click to copy to another event.
I would love to see that to be included as well and also the option to name the event list and maybe not have alread 8 event lists ready, but rather the option (a "+" button) to add another one. Just for to have a better overall overview.
Drag&drop events from one event list to another would come in very handy and how about adding videos from another list to the replay timeline? Let's say I have a prerecorded (not with instant replay) video on my machine and want to include it into the playlist with instant replays. A combination of instant replays and list inputs would be awesome.
Another thing is that I would like to see how long each playlist is, rather than only seeing it while the event list is already played. Just add another row to the bottom that tells us the total duration and shows how many events are in the list.
As I already stated in another post: Name the event...not the camera angle, because the camera angle is already named. And add another row for speed presets.
Here's what it could look like:
#27 Posted : Friday, October 21, 2016 3:21:19 AM(UTC)
vMix 18.0.0.50 Uploaded
http://cdn.vmix.com/download/vmix18preview.exe
Added Periscope streaming provider
Added ability to rename datasource tabs
Added option to convert rows to columns, so FirstName, LastName with three rows becomes FirstName1,LastName1,FirstName2,LastName2 and so on
Google Sheets now requires a Google API Key, to create a key see the vMix 18 Help for instructions
Fixed replay doubling colour correction when playing out duplicate transition frames
Fixed configure sources not working for inputs located after replay in input list when opening preset
Fixed datasource handling of unicode characters
thanks 5 users thanked admin for this useful post.
corporatejames on 10/21/2016(UTC), pop on 10/21/2016(UTC), stigaard on 10/21/2016(UTC), vadim_d on 10/21/2016(UTC), vijay6672 on 10/22/2016(UTC)
zioncast
#28 Posted : Friday, October 21, 2016 5:54:12 AM(UTC)
zioncast
vmix 18.0.0.50
aja io-4k camera input error........??
and... how to live Periscope.....^^
corporatejames
#29 Posted : Friday, October 21, 2016 6:55:34 AM(UTC)
corporatejames
Bug: Datasource titles are not displayed in the dropdown list in Title Editor Datasources.
Convert Rows to Columns working well. Thanks Martin. Very useful change.
sinc747
#30 Posted : Friday, October 21, 2016 1:58:47 PM(UTC)
sinc747
Bug?
vMix 18.0.0.50 uses approximately 40% more network bandwidth on my Production PC than 17.0.0.112 does. Top photo is 17, bottom photo is 18. Used the same profile in both.
- Tom
(My production PC uses an old 100Mbps motherboard.)
sinc747 attached the following image(s):
Ethernet 17-112.PNG (28kb) downloaded 1 time(s).
Ethernet 18-50.PNG (29kb) downloaded 2 time(s).
stigaard
#31 Posted : Friday, October 21, 2016 6:40:58 PM(UTC)
stigaard
Denmark
sinc747 wrote:
Bug?
- Tom
My first thought is that the NDI version in vMix is updated, which perhaps uses more bandwidth to ensure higher quality video streams, or perhaps vMix v18 has added more NDI streams when ticking off the checkboxes in the Output settings, which is naturally increasing the bandwidth usage.
#32 Posted : Friday, October 21, 2016 10:38:19 PM(UTC)
Hi Tom,
Yes, there have been some tweaks to NDI which are in 18 for testing.
One of these is increased bitrate up to around 130Mbps per source depending on content, so all those
who were getting away with using an old 100Mbit network card before will need to upgrade to gigabit like they were suppose to!
Good news is gigabit nics are $20 on Amazon!
sinc747 on 10/22/2016(UTC)
tonylightfoot
#33 Posted : Friday, October 21, 2016 10:56:00 PM(UTC)
tonylightfoot
Hi, Martin
Adding that option to convert row to columns was a stroke of genius!!
The result is this:
This is driven by a Google Slides document that has a macro working in the background that uses the score to automatically sort the data - it works very well.
The process of assigned data field to each text field was a little tedious but well worth it for the result I got.
Thanks again - keep up the great work.
Tony Lightfoot
#34 Posted : Friday, October 21, 2016 11:08:48 PM(UTC)
By the way Tom, the screenshot indicates your network card in that PC supports gigabit, so it could just be the cable
or the switch that is not connecting at gigabit for some reason.
tonylightfoot on 10/21/2016(UTC), sinc747 on 10/22/2016(UTC)
corporatejames
#35 Posted : Saturday, October 22, 2016 12:30:06 AM(UTC)
corporatejames
Yeah I thought that too ;) great work Martin. If you can update the datasources so the names is also displayed in the title editor that would be great but sure its on your big to do list
sinc747
#36 Posted : Saturday, October 22, 2016 1:45:04 AM(UTC)
sinc747
I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot. I am an idiot.
It was the cable!
- Tom
thanks 2 users thanked sinc747 for this useful post.
ON.tv Channels on 10/22/2016(UTC), corporatejames on 10/22/2016(UTC)
StepBackInTime_TV
#37 Posted : Saturday, October 22, 2016 7:48:35 AM(UTC)
StepBackInTime_TV
Was thanked: 17 time(s) in 14 post(s)
Hi Martin - vMix18 is great - thank you. Only had a couple of things so far:
(vMix 18.0.0.50)
1: List Editor does not expand to use the full window area when un-docked - see picture.
2: Activators: Blinking options for square buttons on AKAI APC Mini missing - I have added these to the XML on my system and it works perfectly:
<activatorType displayName="AKAI APCmini Square LED">
<activatorValue displayName="" maximum="1" range="false" displayColor="#00FF00" />
<activatorValue displayName="" maximum="3" range="false" displayColor="#FF0000" />
<activatorValue displayName="" maximum="5" range="false" displayColor="#FFFF00" />
<activatorValue displayName="Green Blink" maximum="2" range="false" displayColor="#00AA00" />
<activatorValue displayName="Red Blink" maximum="4" range="false" displayColor="#AA0000" />
<activatorValue displayName="Yellow Blink" maximum="6" range="false" displayColor="#AAAA00" />
</activatorType>
Keep up the excellent work!
Giles.
thanks 2 users thanked StepBackInTime_TV for this useful post.
stigaard on 10/22/2016(UTC), madness on 10/22/2016(UTC)
madness
#38 Posted : Saturday, October 22, 2016 10:21:22 AM(UTC)
madness
It was the cable!
- Tom
LOL! Been there! Done that!
hubert17
#39 Posted : Saturday, October 22, 2016 10:43:14 AM(UTC)
hubert17
Samson Graphite MD13 isn't supported. Sad. :(
manojhadke
#40 Posted : Saturday, October 22, 2016 10:50:58 AM(UTC)
manojhadke
Hi, Martin
how to link google sheet to data soures...i try but not link..please help
thanks vmix 18 is best....
Guest (10)
7 Pages<1234>»
