Feature Requests
Audio Meters visible when an input is collapsed.
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
I would like to add a suggestion. On my production I use a lot of audio inputs and I keep them collapsed (clicking the top bar so the input is narrow). I control the audio levels with a Korg Nano controller, but I find myself needing a little more info at a glance. It would be great if the audio meter bar could still be visible while the input is collapsed. I find myself opening the input to see if the audio levels are correct or even being detected at all. even a small sliver on the side would be enough to display the audio levels and the color could still be used to determine the status (ON or OFF) of the input itself.
I do use the audio mixer interface but I don't have it open full time while running my production. Thanks for the consideration.
Chuck P
Feature Requests
