Joined: 12/28/2015(UTC) Posts: 2 Location: Albany Western Australia
Hi, I've been Running VMix basic for around a year now, would like to Upgrade to VMix HD, Tried installing the Demo but my computer keeps on opening Vmix Basic. So I uninstalled VMix Basic Restarted it. Then Installed the Demo. When it opens it keeps going back to VMix Basic version. How do I get the Demo to Run so That I can check if The equipment we are using 'ie' the projector and laptop will work with the better quallity outputs and extra inputs. I've tried installing the demo 4/5 times now. Regards Ben
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
After installing and running the first time you see the vMix Registration Window.
Choose the option 'Register for a fully functional 60 day trial'
Joined: 2/14/2016(UTC) Posts: 117  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
... you don't have to do a new install... just goto settings/about, there you can change registration key (change the basic key for a trial key)...
