coskel22
#1 Posted : 8 years ago
coskel22
Does it give you 4 inputs and 2 separate outputs + HDMI output?
The datasheet is not clear.
I use vMix with a custom built machine right now, looking to use this as an Instant Replay deck.
Would the IR software be extra or is that included?
http://www.vmix.com/software/vmix-replay.aspx
Shuttle Pro? Cost?
Thanks, Kel
