ne02005
#1 Posted : Friday, October 7, 2016 8:53:30 AM(UTC)
ne02005
Is this device compatible with Vmix??
https://www.amazon.com/R...mp;keywords=Razer+Ripsaw
thanks
dionv
#2 Posted : Tuesday, February 14, 2017 11:32:42 AM(UTC)
dionv
thanks
Maybe not explicitly compatible, but I tested one over the weekend Feb, 12, 2017), and it worked with vMix 18.x
(A bit late to the game, but just in case someone else stumbles across this question later, at least there's an answer.)
Dion
Yamato
#3 Posted : Friday, February 17, 2017 6:48:55 PM(UTC)
Yamato
It's an Avermedia Live Gamer Extreme with a Razer branding on it, if you compare both devices, connectors layout is the exact same.
Thremir
#4 Posted : Friday, February 17, 2017 7:29:49 PM(UTC)
Thremir
Yup.
http://imgur.com/a/JCSmO
Bamboo
#5 Posted : Sunday, February 19, 2017 8:32:19 PM(UTC)
Bamboo
I just set up the Razer at home and Vmix sees it, but I cannot figure out how to make it work because it says resolutions are not supported, etc.
What settings did you use to make it work in VMix? Any settings need to be done with teh Razer software to make it work?
I am using it with HDMI output from a Panasonic HC-V770.
All help will be greatly appreciated!
I am getting the Vmix system to see the Razer Capture device, and even getting some input , but the display says "Signal out of Range". I changed teh resolution to 720x480 YUY2, but nothing happening. Ideas?
Thanks a ton!
Bamboo
avsoundguy
#6 Posted : Monday, February 20, 2017 4:13:21 AM(UTC)
avsoundguy
What edition and version of vMix are you using?
dionv
#7 Posted : Tuesday, February 21, 2017 12:23:44 PM(UTC)
dionv
Hi Bamboo,
I was testing a Ripsaw with vMix v18.x, bringing the input in from a BlackMagic Studio at 1080i/59.94 with no issue.
I see that the camera you are using is 4K-capable. If you haven't already, check the HDMI-out settings for it to make sure it is outputting no more than 1080, as I don't think the Ripsaw will accept anything higher.
Hopefully this help.
Dion
dionv attached the following image(s):
