Hardware Compatibility
x-Keys xk68 Jog and Shuttle compatibility
Joined: 10/25/2012(UTC) Posts: 182 Location: Barbados
Hi, Can anyone confirm if the X-Keys XK68 Jog and Shuttle is fully compatible with vMix? I am looking to use it as a Replay Controller but it is not listed in the approved Hardware List.
Maxi
@ Maximus From what I can remember from the September edition of "Vmix Fun Time Live Show", if it isn't already supported, it will be in vMix 18: Ice
Thanks: 8 times Was thanked: 6 time(s) in 6 post(s)
I just programmed ours yesterday using the midi function. It works now.
Thanks for info. I subsequently found it listed as supported for vMix on the Xkeys website, so it should work just fine. @ g-mo, let me know how the jog wheels work for you. I presume you are using it for Replay.
Thanks much Maxi
