66 Pages«<678910>»
elgarf
#141 Posted : Tuesday, September 27, 2016 4:24:39 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
Updated controller with DataSource property for list widget.
Be careful with big data sources (for example >100 items in external data control), it can slow down controller.
First post
thanks 2 users thanked elgarf for this useful post.
corporatejames on 9/27/2016(UTC), Jedda on 9/27/2016(UTC)
corporatejames
#142 Posted : Tuesday, September 27, 2016 7:53:21 AM(UTC)
corporatejames
data list works well. Good update.
Jedda
#143 Posted : Tuesday, September 27, 2016 10:18:26 PM(UTC)
Jedda
elgarf: Is there any reason to believe that my issue here could be related to UTC somehow? I would guess not, but just asking
http://forums.vmix.com/d....aspx?g=posts&t=6884
elgarf
#144 Posted : Tuesday, September 27, 2016 11:20:42 PM(UTC)
elgarf
Russian Federation
@Jedda, if you have used internal vMix countdown (just buttons with start/stop countdown commands in UTC), so UTC doesn't affect this timer. But internal timer widget in UTC can be not very precise, I'll look into it one more time.
Jedda
#145 Posted : Wednesday, September 28, 2016 12:05:45 AM(UTC)
Jedda
I'm using a timer widget in UTC with separate buttons to start/stop, so maybe that could be one reason for my problems. Has not really been an issue before, but started to be a month ago. Maybe could be when you add more and more things to the .vmc file it starts to affect the timer slightly?
elgarf
#146 Posted : Wednesday, September 28, 2016 12:17:59 AM(UTC)
elgarf
Russian Federation
Maybe, at this time just use vMix timer for precise things.
elgarf
#147 Posted : Wednesday, September 28, 2016 2:02:51 AM(UTC)
elgarf
Russian Federation
I'll made changes in timer widget, so you can re-download UTC, and try it out.
First post
corporatejames
#148 Posted : Wednesday, September 28, 2016 3:28:57 AM(UTC)
corporatejames
First post
Will give it a test and let you know if any problems
Update: any reason why it now seems to skip 2 seconds when you pause and start again ??
elgarf
#149 Posted : Wednesday, September 28, 2016 3:50:51 AM(UTC)
elgarf
Russian Federation
It counts milliseconds now, you pause at 0,5 sec, and it remember that)
corporatejames
#150 Posted : Friday, September 30, 2016 2:36:31 AM(UTC)
corporatejames
I think there is bug in the list widget now that the existing text list does not update vmix txt field.
in the recent update this week seemed to brake it. ???
elgarf
#151 Posted : Friday, September 30, 2016 2:51:34 AM(UTC)
elgarf
Russian Federation
@coropratejames, now fixed)
thanks 1 user thanked elgarf for this useful post.
corporatejames on 9/30/2016(UTC)
corporatejames
#152 Posted : Friday, September 30, 2016 3:46:56 AM(UTC)
corporatejames
Yeap working again. :)
corporatejames
#153 Posted : Friday, September 30, 2016 3:49:27 AM(UTC)
corporatejames
Also it possible to lock the the assigned "input name" to mapping.
So that if the inputs are moved or not in their original numbered location when you update state
you don't have to remap again ?
Eg when create a new preset etc
elgarf
#154 Posted : Friday, September 30, 2016 3:54:22 AM(UTC)
elgarf
Russian Federation
There is lock on input name, test it widely.
corporatejames
#155 Posted : Friday, September 30, 2016 4:17:43 AM(UTC)
corporatejames
Not the padlock on the widget but within the command config that it locks or remembers the name of the input.
If you add a input in front of existing input it will mix up all the other widgets that are already assigned as
they a based on input number order.
elgarf
#156 Posted : Friday, September 30, 2016 4:44:29 AM(UTC)
elgarf
Russian Federation
@corporatejames, you need UpdateState in UTC, when you add/remove input in vMix. In most cases UTC keep assigned inputs.
corporatejames
#157 Posted : Friday, September 30, 2016 5:04:13 AM(UTC)
corporatejames
I have done that but doesn't always remember the assigned name. But will keep an eye on it and
let you know if needs to be looked at further as I'm setting up a standard layout
to used by multiple people so can share.
Jedda
#158 Posted : Sunday, October 2, 2016 1:21:09 PM(UTC)
Jedda
First post
I think I found the problem in my case. For some reason the UTC has created multiple clock widgets in the vmc file for me, so there are clocks running in the background which is all sending information to the same title. Seems like it basically somehow has created mutiple layers of all the stuff I have created in my vmc file. Any idea why this is happening? I know for sure I have not created those, it's just multiple copies of what I have created once. I can send the vmc file later if you want to look at it, cause I have a feeling there's some kind of bug somewhere which causes this. Probably need to re-create my whole vmc file, since this issue kind of spread to other parts, like the importing to lineups I use which stopped working today because it's probably sending the data to fields which is behind my actual ones.
elgarf
#159 Posted : Wednesday, October 5, 2016 10:41:10 AM(UTC)
elgarf
Russian Federation
@Jedda, I think I forgot to clear widgets on controller loading, so if you save and then load controller, it has double widgets.
Also fixed bug, when some data does not updating (multiple mappings through many components).
First post
Jedda
#160 Posted : Wednesday, October 5, 2016 11:16:32 AM(UTC)
Jedda
First post
Do I need to do anything with my vmc file now (load it and save maybe?), or should I just download the latest version and it should work? Or is my vmc file fucked for life and needs to be fixed manually?
Guest (39)
66 Pages«<678910>»
