Maximus
#1 Posted : Wednesday, September 21, 2016 12:46:36 PM(UTC)
Maximus
I am trying to pull in an MPEG-TS stream from WOWZA Server using their Stream Target Config Tool. So far I have had no luck, and I can't find anything that helps using web searches. Has anyone successfully done this? The WOWZA server is working correctly as I can send to other Stream Targets, but I want to bring a feed into vMix. Any suggestions would be appreciated.
Maxi
Followyourblissmedia
#2 Posted : Friday, June 2, 2017 3:01:12 PM(UTC)
I need help with this too. Trying to ingest the video from my JVC HM200 into Vmix and haven't been able to do it locally via rtsp. How can we take the stream from a wowza server and use as an input in Vmix?
hbb
#3 Posted : Friday, June 2, 2017 9:52:26 PM(UTC)
hbb
use new vlc mode unless wowza is on same box as vmix
Guest (4)
