2 Pages<12
matthewfrey
#21 Posted : Tuesday, September 20, 2016 6:18:15 PM(UTC)
matthewfrey
I have a couple of the Timeleak HD72A's With just one installed - it works great - but Ive been trying to add a second to the same system and its just not working.. with the second one installed - I love the signal to the first - and i'll either have a green or redish hue on the second cards feed.
Just curious if anyone has had success using two of these cards?
Windows 8.1
MSI 170a PC MAte
Core i7 6700
GTX 950
Matthew
wanted99
#22 Posted : Friday, October 7, 2016 1:34:58 PM(UTC)
wanted99
Windows 8.1
MSI 170a PC MAte
Core i7 6700
GTX 950
Matthew
Hi i have the same problem but now i can Stream 2 card at same time.
Install One card, start streaming.
Install second card, start streaming. and not reboot.
if you have conflict or green image. just force Windows to reinstaller driver again.
It's a bad solution. But work. When you not have blue screen ;)
2 Pages<12
