10 sec max for Shortcut key for saving video delay???
It would seem that when using the Shortcut Key to save the video delay, the maximum time allowed is 9999 ms, is this correct? I would like to save between 13-16 seconds or even 20 seconds in some cases, as it is set up when clicking on "save". I like using the shortcut keys much more than the mouse as it is sometimes just too time consuming to navigate through 4 or 5 rows of input screens during a live game. Also, not sure if is some sort of bug but the playback speed often seems to self-ajust or reset to 2x (from .5x) without me noticing until I go to it on air. Not sure how or why this happens, I usually have 2 or more video delays going set to .5x (one for each camera, take one to air for instant replay and save the other to disk via advanced trigger setting)
Love the product Martin, you're doing a great job with it!
i7 950 3.07GHz 24GB Ram vMix SD x64 8.0.0.8
Joined: 1/13/2010(UTC) Posts: 5,350  Location: Gold Coast, Australia Was thanked: 4759 time(s) in 1633 post(s)
The SaveVideoDelay shortcut will be expanded to up to 120000 milliseconds (2 minutes) in the next release. It was set to 9999 as this was the maximum for transition durations but this obviously should not apply to the video delay.
As for the playback speed changing, this may be caused by a mouse scroll or key press changing the selection if is currently the active control. The control has been changed for the next release to avoid this situation.
Martin vMix
