rrpro
#1 Posted : Monday, September 19, 2016 4:05:23 PM(UTC)
rrpro
Hi!
I'm trying to move my production to HD and I had an Avermedia LGP Lite and I wanted to test. Unfortunatelly I can't seem to add as a camera, I always get: "AddNewInput
The device doesn't recognize the command"
Is there a way to check the exact problem?
Anyone got the device to work? The price is very nice and it works well on other softwares and directly on FFMpeg
-TA_
#2 Posted : Monday, September 19, 2016 4:13:00 PM(UTC)
-TA_
rrpro wrote:
Hi!
It works with 32bit vMix
rrpro
#3 Posted : Monday, September 19, 2016 5:02:44 PM(UTC)
rrpro
Directly or just with Stream Engine? On my it works with Stream Engine but is a bit slower :(
KJ4AWR
#4 Posted : Wednesday, September 21, 2016 3:55:19 PM(UTC)
KJ4AWR
It works in 32 bit with the stream engine. I've never gotten it to work otherwise.
Luke
#5 Posted : Tuesday, October 18, 2016 11:12:49 PM(UTC)
Luke
We've used an LGP going on 3 years now on both 32 and 64 systems. Stream engine is def required. I've found when having issues a restart often helps and be sure to NOT have VLC and any other DirectShow capable apps running before vMix is up and running with the LGP as an input
Guest (5)
Similar Topics
AVERMEDIA LGP Lite (Feature Requests)
by -TA_ 7/15/2015 2:43:18 AM(UTC)
