scrolling input rows: thumbnails disappear
Hi Martin, I tested this morning my system with 4 cameras and a BMD Decklink Quad and I am impressed with all the possibilities. The Multicorder worked reasonable, I saw 120 dropped on the first input for about 5 seconds and then all 4 channels recorded without a problem I'm not sure what caused the first input to drop frames, and for some reason that channel showed 4 seconds more recording time than the other 3. Cameras: 2 x Sony EX3, 1x Epic-X and 1x Alexa Will test some more next week.
I had also activated several backgrounds and animations (mpg's) on the 2nd and 3rd row but for some reason they went black the moment I scrolled the inputs. double clicking each makes them visible again, with the "i" page in front.
I use the Asus ATI 7850 and use that card for the program screen and the output screen as well, no internal graphics.
Rob
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Hi Rob,
Are you using Windows 8 by any chance? I've seen this blank input thumbnail issue testing under Windows 8 with a lot of static inputs loaded. It might also affect Windows 7 under certain circumstances.
It will be fixed in the final vMix 8 release.
Martin vMix
Hi Martin, I am using W7 (64bit)
anyway, good to see you are working on it.
Rob
