snitzer
#1 Posted : Friday, September 9, 2016 6:22:42 AM(UTC)
snitzer
Please increase the amount of stinger slots available.
Two is not enough for us. We use 5 per show, and have to quickly manually switch between them now.
Thanks.
anthony
video director / RMGTV
roverradio.com
Ed Tech
#2 Posted : Friday, September 9, 2016 6:54:38 AM(UTC)
Ed Tech
+1 Any increase in the number of stingers would be great.
Thanks for your consideration.
stigaard
#3 Posted : Friday, September 9, 2016 7:18:59 AM(UTC)
stigaard
Denmark
+1
#4 Posted : Friday, September 9, 2016 7:49:19 AM(UTC)
+ 1
Peter B
#5 Posted : Saturday, September 10, 2016 2:33:08 PM(UTC)
Peter B
+1
I have been able to work around this by using an overlay and then triggering a background transition behind the overlay at some point. This has the huge advantage of being able to use transitions other than a cut when the stinger is a logo or a graphic element that doesn't go full frame to mask the cut.
For instance the overlay element can drag the preview source on using a wipe. Good for a hamburger stinger as seen in the last show where the burgers don't and shouldn't go full frame.
Of course, simply more stinger choices in the pull down is the best way to go and PLEASE can we have the choice of a cut or fade in the stinger background transition setup. It enables a lot more creative options.
sinc747
#6 Posted : Saturday, September 10, 2016 2:55:32 PM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
+1
jip
#7 Posted : Monday, September 12, 2016 6:49:52 AM(UTC)
jip
Estonia
+1
JimJacobs
#8 Posted : Monday, September 12, 2016 11:31:25 AM(UTC)
JimJacobs
+1
Follow Your Bliss Media
#9 Posted : Friday, August 14, 2020 9:56:51 AM(UTC)
+1
Has there been any more discussion on adding more stingers as well as allowing transitions such as wipe or fade for stingers?
gpdipalmerahtimur
#10 Posted : Friday, August 14, 2020 1:41:51 PM(UTC)
gpdipalmerahtimur
Indonesia
+1
Thanks for requesting this.
Geoff B
#11 Posted : Monday, August 17, 2020 8:02:55 AM(UTC)
Geoff B
Originally Posted by: Follow Your Bliss Media Go to Quoted Post
+1
You can easily do this using triggers. You can have as many keyable "stingers" as you want, and use any transition underneath the animation. Just set an "OnOverlayIn" trigger to do the transition, and add some delay to that if needed. Set an "OnComplettion" to take the overlay off. Then you just need a shortcut to send the input of your PNG sequence to the right overlay.
