3rd Party Software and Development
Custom "Activators" windows program for Akai MIDI controllers (APC Mini and MIDI Mix)
Joined: 9/9/2016(UTC) Posts: 23  Location: Fresh Start Church Thanks: 2 times Was thanked: 3 time(s) in 3 post(s)
Feature request: Is there a save option? When I close the program and reopen it, everything I've added is gone.
 1 user thanked thinkcustom for this useful post.
You have been a member since:: 5/20/2015(UTC) Posts: 492   Location: Copenhagen, Denmark Thanks: 422 times Was thanked: 102 time(s) in 79 post(s)
thinkcustom wrote:Feature request: Is there a save option? When I close the program and reopen it, everything I've added is gone. I've released a new version - v0.2.1 - which enables save/open of presets! :-) You can find the download link in the start of this thread. Please enjoy, and send some feedback on your experience of the program.
 1 user thanked stigaard for this useful post.
Another feature added, is the opportunity to change the url which is used to connect to the webcontroller, which actually allows to run this program on another PC.
Furthermore, the program also got improvements, showing the the state of the connection to the webcontroller.
I've just released v0.2.2, fixing a major bug on loading presets.
Thanks!
But it does not work with 17.0.0.12 (
linroot wrote:Thanks!
But it does not work with 17.0.0.12 ( Hi, due to the fact that the beta of vMix 18 is out, which is pretty stable, I would recommend you to try vMix 18. You can download it here at the forums. Cheers!
stigaard wrote:linroot wrote:Thanks!
But it does not work with 17.0.0.12 ( Hi, due to the fact that the beta of vMix 18 is out, which is pretty stable, I would recommend you to try vMix 18. You can download it here at the forums. Cheers! Thank you for you work, it is great! I think that not every one will upgrade to 18 vers soon and it is still not perfectly stable for production. Is it any way to make some changes so it worked in 17.0.0.12? One more time, thank for you work.
