Instant Replay
Remove "same input format" limitation
Thanks: 5 times Was thanked: 2 time(s) in 1 post(s)
As easy as saving each input feed in different files/folders, independant of the configured feed.
I need this because some times I have multiple cameras with different input formats (576i, 480p, etc) and I can't think a valid reason that replay needs to limit to only one format. I have to play with vlc, stream option and RTSP output to output them to the same format, but that's an horrible hack.
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
agree would be good to be able to change format. I have tried using a 720p setup and V mix will not let me do replays with 720p as it only wants to do 1920 x 1080 option is greyed out so cannot be changed. Have tried making a whole new preset but to no avail so far. So only option is to make a 1920 x 1080 session even though all the cameras are set to 720p ?
Close the replay input. Now open a new one and create a new target directory. You should be able to set your cameras now.
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ Llorx
AFAIK all cameras have to match because of how "vMix Instant Replay" records and accesses files (single file, multiple cameras). If you need to record multiple angles from different format cameras, I would suggest the "MultiCorder" feature and/or setting up video delays for each input if your system can handle it.
@ mark
vMix "Replay" defaults to the last session's record settings. If you want to make any changes, you have to start a brand new session as 'ask' says above.
Instant Replay
